AARDVARK122
john
utah
2007 volvo xc70
So I have had a lot of different people ask about my Heritage Grill. So here is a simple diy on how to make your own Heritage Grill.
I started with the base Bronco grill. Had it painted white. Then I took the Bronco letters off and went to Home Depot and got an aluminum door kick for $25.00. I cut it down to fit the distance across the grill where the letters were. Had it painted to match the grill. Then just applied double sided gorilla tape. And stuck the aluminum piece on and then applied the red F O R D letters I got from juggernaut. It is really that simple. I also had the outside part of the grill color matched to the bronco, so the white part wasn’t so big. It is your choice on how much white you want on your grill, but the letters and heritage part are super easy.
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering 96FE4EBD-4913-4A33-990A-565381512E09
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering FF471F5B-16DF-4772-BABC-029084C143AC
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering 2C6BF8CE-ECA5-4252-855A-9F73AF8CB3C7
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering 52C83E8A-1515-4E5E-8597-1DF5FFC3DAC8
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering 9E771020-C1CF-4873-A8C6-E7FDC3A60142
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering 9A198973-0CA3-4DE7-9FED-19E02C74B5E7
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
I looked at some flat aluminum, but it was a little too thick for what I was trying to do. I wanted the grill piece to be as thin and flat as possible so it would blend in and not look like I put the piece on.
myrealname123
Trent
Monterey, CA
'21 Bronco
This is the grill we should have gotten, IMHO. The Bronco script on the quarter panels would make sense with this. Otherwise, just feels like it's broncobroncobroncobronco all over.
mbagne
Placentia, CA
Mach-E GT
Ford Bronco DIY budget Heritage Grill w/ FORD Lettering 6EFB72E5-DD66-4B1E-9B74-F61040A3A7FE
Very nice! You say that you got the FORD letters from "juggernaut" . . . what is that?
F OR D
BD Green Machine
unacceptable! we need a 500-999 aftermarket grill or kit.
just kidding, that is fantastic and something i may consider.
i'm with @mbagne what is this juggernaut you speak of?
AARDVARK122
AARDVARK122
john
utah
2007 volvo xc70
Exactly. I wish they would have done more Ford branding.
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
