AlanP
Alan
New Jersey
2021 Bronco OBX SAS Antimatter Blue
UPDATE: 1 month later I've gone through 2 drive through car washes and offroading through brambles and the mudflaps are holding firm. And so is my paint job!
Eventually someone will come out with a proper mudflap for an SAS with factory side step bars. But my paintjob won't wait that long. Someone else had posted a pic of modifying the factory mudflaps so I purchased them. Ford part #M2DZ16A550AA. Here's how easy it is to mount them. I'm just a garage mechanice:
1. Turn the wheel to get it out of the way. For right side flap turn it left. For left side flap turn it right.
2. Remove the 2 screw plugs from the bottom of the inner fender lining and either remove the fender flare or at least the first 2 latches:
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_163851057
2. Line the holes in the flap with the 2 holes in the inner fender. I put a screwdriver in each hole to keep them aligned.
3. Using a pencil, trace the area you'll need to cut to clear the step. Remove from the car and then use a sharpie of the pencil so you can see the line better:
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_163313901
4. Using a Dremel tool or your favorite cutting device, cut the hole. Better to cut small and then have to go back and cut more:
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_163342317
I used a side cutter to make neat corners:
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_163739231
Test fit. You'll find that the the further you slide the flap onto the step the larger the hole will need to be. You'll want the flap to rest against the inner fender without flexing it. Once you're done you can clean up the edges of your hole with a file or sandpaper.
5. You'll need to trim the top of the flap off in order to clear the fender flare. Put the fender flare back in place, line the flap up with the 2 holes again, and now you can trace out the cut to the flap:
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_165132355
That's it. Put it all together now. The mudflap kit comes with some extra bolts if you want to secure it in place with more then the 2 screws. I did a test drive at 85mph and they didn't loosen. And there's no rub on the tires lock to lock. Easy peasy!
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_171123205
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_171001057.MP
Ford Bronco DIY dremel solution - how to mount Ford Front Mudflaps on Sasquatch with Step Bars PXL_20211126_165318837
Note that the rear mudflaps part #M2DZ16A550BB have 3 screwholes that you'd think would line up with the 3 screwholes in the rear bumper but they don't. So you'll need to drill new holes to mount those. Should be easy peasy with no cutting but I haven't done so yet.
dcaero
Bronco OBX SAS
Very clever, I expect others to follow as this is a cheap fix!
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
Thank you Alan..... and the rear set M2DZ16A550BB. I appreciate your post as I just went on line and ordered . I'm still always surprised at how different the prices are when searching .
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Omg...your adorable. Thank you.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
Mud flaps are nearly as pervasive as scripts on four doors.
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
i'm surprised somebody hasnt made a template that the community can download and use to cut out the flaps.. :)
<hint hint>
LOL
Oceannomad
Jonathan
SE Virginia
2021 Audi Q7
Cool, adding a dremel tool to my Christmas wish list
buzpro
Binky
Tacoma
AGAIN, I'm surprised at Ford .... how can they sell these mud flaps without the cutouts being pre-cut, when they know there is interference!
lakesinai
Charleston SC
How noisey are those Territory tires at 75-80 mph? Do they handle well?
AlanP
AlanP
Alan
New Jersey
Compared to my soft top JK the Bronco 2dr hardtop is quieter. Bir I will go to a quieter BF Goodrich all terrain when these wear out.
AlanP
AlanP
Alan
New Jersey
Judging by how different the alignment was from the left to the right, I wouldn't trust Ford to have each vehicle built identical enough lol
RogueSqdn
Advance, NC
I'm glad I ran into this thread. I just got my FE on Friday and had to get the step bars put on for my wife's mobility issues. I've already picked a few rocks out of the tires and am concerned about the paint.
