- Paul
- May 7, 2022
- 6
- 56
- 60
- Central New Jersey
- ‘22 BB Sas, ‘14 Raptor, ‘71 Hemi ‘Cuda convertble
- Big Bend
Thank you - I’ll check with them.
After mounting the plug in the stock position as seen in the picture above I can see it's going to get scraped off the first time I come off a steep decent. So I'm going to relocate it facing down on the backside of the bumper. I'm going to double insulate it as it's now going to be closer to the muffler. I'm probably going to fabricate a second bracket to move the plug into that position.I'm in the middle of doing the full install using Roverdudes guide. Wiring up the C201 and C105 plugs was kinda tricky but so far things tested correctly. I also have a BAMF hitch receiver so I'm trying to decide where I want the plug located.
I was thinking the same thing, on the driver side there's a couple bolts that will fit the bracket that came with my 7/4 plug well plug pointing straight down. Good excuse to get an aftermarket exhaust with a smaller mufflerAfter mounting the plug in the stock position as seen in the picture above I can see it's going to get scraped off the first time I come off a steep decent. So I'm going to relocate it facing down on the backside of the bumper. I'm going to double insulate it as it's now going to be closer to the muffler. I'm probably going to fabricate a second bracket to move the plug into that position.
This is how I plan to mount my plug. It will get scraped off in the OE position. Let us know about the Tow Feature and Sway Control on your screen please.I completed my install and did the forscan programming as well. There were maybe 3 or 4 lines that didn't have the same before-values like Roverdude had, so I skipped those for now. I have the 12V charge line working, and no error codes on anything so thats good. I forgot to check the dash to see if the tow option was now there. I have a friend that has a completely identical build to mine except his has the factory tow package so if I have any issues then I'll check his modules.
Here's a pic of where I decided to put the plug for now. I have heat reflective tape on order to help mitigate heat from the muffler. If I have any serious melting issues then I'll go with an aftermarket muffler or consider switching to the factory tow hitch and plug. This setup should be good to go for getting an ultra light camper trailer to Super Celebration West in a few weeks though.
Out of curiosity, what lines were different? or what values did you have? (you can PM me your vin so i can pull the asbuild data too if wanted.)I completed my install and did the forscan programming as well. There were maybe 3 or 4 lines that didn't have the same before-values like Roverdude had, so I skipped those for now. I have the 12V charge line working, and no error codes on anything so thats good.
Looks like it is enabled as expected.This is how I plan to mount my plug. It will get scraped off in the OE position. Let us know about the Tow Feature and Sway Control on your screen please.
Great news!Looks like it is enabled as expected.
You have the BAMF hitch receiver too, have you had any issues getting the hitch pin through the holes? On mine the coating is so thick I can't get the 2 different pins I have to go through. I might have to widen the holeGreat news!
I used a rat tail file to it. The powder coating makes it too tightYou have the BAMF hitch too, have you
I tried my best with the overview that I wrote up. I don't write technical manuals for a living so.... It was the best I could do.Thank you Rover Dude!
Even with my first car being a Triumph (Lucas Electrical - the Prince of Darkness) and a Land Rover owner, I was hesitant to tackle this job and get into opening up a modern wiring harness and pinning additional wires. After studying your guide for a couple hours going back and forth between your pictures and steps I felt confident enough that I could attempt this. I currently have everything installed, wired up, and coded in Forscan. For some reason I can't get the U21000 DTC code in the TRM to clear, however everything is working including the 12V and the brake controller so I’m going to leave it for now.
For anyone looking to attempt this, it took me about 8 hours total doing it by myself. I was very hesitant to pull my interior apart and 2 body harnesses … if you read Rover Dude’s instructions it’s very doable. My most ambitious mechanic work prior to this would have been brake jobs and control arm and very minor electrical (fuses and relays). I usually would have a trusted mechanic do this work but other than Rover Dude’s write up there is no service manual to do this and most mechanics will not tackle this job. The hardest part was the addition of the 1 wire in position 40 of C105 and then the 5 wires in position 15-19 of C201. Luckily this is the area that Rover Dude did take lots of detailed pics and gave a detailed guide on how to do it. Pulling the panels took about 30 minutes and the only real catch are the 2 bolts that Rover Dude mentions on the drivers kick panel foot rest. If you have never done it before I would recommend searching and watching some YouTube videos on how to remove the tail light (detailing cape cod has a good one), how to remove the rear cargo panel (Overlanding4fun has a good video) and removing the rear bumper (Fishbone offroad).
You can learn forscan pretty easily from the master thread on B6g that has links to videos and explains what is needed. The bonus to this job is I have Forscan now and can personalize a bunch of functions.
I figure this cost me minimally more than If I had ordered tow from the factory and added the brake controller. I used some Ford Pass points and I’m probably about $850 into this including forscan, OBDII connector, wire, pins, some tools, etc… plus 8 hours of my time. What I got was worth more than that! I have the confidence and knowledge learned from tearing apart my bronco and wiring a tow harness to the factory harness and programming everything to work.
