Hi,There are a couple of metal screws that screw into a metal frame that surround the fuse box. I used one just to the right of it where the dash panel is pulled out from. I recommend to double check they are properly grounded using a 12 volt light tester or multimeter, just in case. However, one of those should work for you as well as long as its a metal screw going in a metal frame (not metal to plastic).
Cool, I did the same to the right and hooked into the metal screw into the metal base.
Thanks for the reply.
Cheers,
HD
