- ORACLE
- Mar 13, 2020
- 19
- 591
- 1,987
- New Orleans, LA
- Website
- oraclelights.com
- Bronco
- Undecided
Install Video is now up!
Correct, just cut off the relay and run the wires that were going to the relay to the Aux switch.Great video. Cant wait for these to ship. I suspect most people will use the Broncos upfitter switches to power these, so will need to cut the relay and switch off.
We always love the installation videos. However the parts needed are NOT in the glove box btw. You may want to edit that. You need a TP40 (TorxPlus 40). The TP40 is NOT included in the kit, neither is a T40. Customers have to get those bits on their own.Install Video is now up!
Thanks! Our dealer convinced us that our Bronco didn't have the tool because it was not equipped with the mod bumper from the factory and if you had the mod bumper on the original build the T40 was in the factory kit. We will update the video.We always love the installation videos. However the parts needed are NOT in the glove box btw. You may want to edit that. You need a TP40 (TorxPlus 40). The TP40 is NOT included in the kit, neither is a T40. Customers have to get those bits on their own.
Naw Ford doesn't give you half what you need. They also don't give you the 2nd bit for the a-pillars since there are 2 required.Thanks! Our dealer convinced us that our Bronco didn't have the tool because it was not equipped with the mod bumper from the factory and if you had the mod bumper on the original build the T40 was in the factory kit. We will update the video.
We won't have instructions for this, but you can tap the existing wires into the factory harness. If you cut the wires after the DTM connectors on the ORACLE fogs, you'll have a red & black wire to tap in & still have a quick disconnect.I have a factory plastic bumper with factory fog lights.
I am replacing this bumper with the factory steel HD MOD bumper.
I am NOT planning to connect these lights to the Aux Switches or included relay!
Will the included instructions give me guidance on how to connect your fog lights to the existing factory fog light harness/wiring?
Will i need to source special or specific harnesses or connections to complete this install?
You have three options:We won't have instructions for this, but you can tap the existing wires into the factory harness. If you cut the wires after the DTM connectors on the ORACLE fogs, you'll have a red & black wire to tap in & still have a quick disconnect.
Yes. Obviously if you're going from a plastic bumper and OEM fogs like @B A C N O W you don't need additional Ford parts.You have three options:
1. Use the supplied wiring harness supplied with the lights to thread a wire to the interior of the cabin and mount a switch that is connected to the harness somewhere on your dashboard.
2. You can modify the existing harness and wire it to the uplifter switches if you have those on your Bronco
3. You can also modify the harness and wire it to the pre-wired fog light wires on the mod bumper. You would need additional ford parts for the light/headlight/fog switch to replace the existing switch
Did I get that right?
