I actually have a manual in the shop today. There's a boot right behind the clutch pedal you can poke through. Goes right into the engine compartment.I just received my # 5890 Oracle Fog Light Kit. I have no pass-through grommet in my firewall, I guess due to having a clutch pedal? Where should I send the factory switch through the firewall in the best way? No, I did not order the Aux switches.
I didn't really see an easy way to get to that one on the engine compartment side, but I was more focused on the larger grommet. Could have missed it!I may even try the tiny grommet directly above the large one?
I have been thinking about ordering a new Ford headlight switch with the fog light push button. Could I wire the Oracle fog lights to it? If so, where do the wires attach in the switch?I didn't really see an easy way to get to that one on the engine compartment side, but I was more focused on the larger grommet. Could have missed it!
I’m not sure that’s possible without having Ford’s fog-light harness in the bumper.I have been thinking about ordering a new Ford headlight switch with the fog light push button. Could I wire the Oracle fog lights to it? If so, where do the wires attach in the switch?
Yea, I think that may be the case, as I have no factory fog light harness on my truck.I’m not sure that’s possible without having Ford’s fog-light harness in the bumper.
Hey Mark,Got mine installed. Kind of disappointed in the light color. Expected it to match the turn signal amber color but it’s much more yellow.
I know; old thread. I just got this Oracle kit and installed them on my '23 WT Squatch 4-dr. I used upfitter switch number 2 (number 1 is the overhead light bar) following closely the approach in this video:
CUPRA Oracle install video
Came out great first time. I did put some mammoth shrink tubing on the connectors near the fog lights, and shrink tubing wherever possible elsewhere. Couldn't get a front shot--too much glare from the overheads!
Sure!Any chance you have photos of how they look in the day light. Looking at putting the same in my WT. do you have a link on the oracle sight of the exact ones you put in?
Thanks
Great photos! Looks like you may have forgotten to remove the clear protective film over the lenses on the passenger side.Sure!
If you want, I can take pictures later of the wiring installation.
And this is the kit: Oracle triple fog light kit
