Do you guys think future larger engine option might increase tow capacity?
VailDan
Dan
TN
2D Badlands(2023)
Hey Guys,
The Bronco shows a tow capacity of 3500lbs, but I would love a future option that might tow a four or 5000 lbs. I did notice the tow capacity is the exact same for both the 4 and 6 cylinder, so I am guessing that is all the frame, suspension, etc. can handle? A lot of this is guessing, but if the future Bronco does get a Raptor engine, etc. do you guys think there is any chance the tow capacity increases?
Jdc
Jon
Massachusetts
Bronco Badlands
Hey Guys,
Why would that help if there's no difference in towing capacity between the 2.3 and 2.7? The 2.3 in the ranger can tow up to 7500 lbs
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
Think Transmission.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
No, both the 2.3 tows more in the Ranger, and the 2.7 in the F150. It is the springs made for articulation. At some point I figure they’ll do a max tow version with rear suspension and cooling adjustments, and maybe bigger brakes.
John Bronco
Ram 2500/ Jeep Rubicon
Probably not. Frame, suspension, and tires are the main limiting factors.
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
Hey Guys,
No. The 2.7 EB in the F150 can tow like 8000 pounds. The bronco is limited by its suspension, height and length.
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
bigger engine has nothing to do with the towing capacity.
Michael Haun
WV
2021 Bronco Badlands CO
That's why the Jeep Gladiator can tow more than the Wranglers they went to different suspension and rear axel.
VailDan
VailDan
Dan
TN
2D Badlands(2023)
Thanks guys. That is what I was guessing, but was just wanted to make sure.
regularbronco
Shawn
F150 Platinum
All the above are correct, and the differences are likely due to the SAE j2807 procedure. For vehicles under 8600 lbs GVW, the vehicle must use EPA mass, wheelbase, unsprung weight, ride height, and many other factors that you can feel free to look up. Way too much to unpack and one thread!
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Nope. Horsepower is not the limiting factor. Suspension, brakes, and center of gravity are what holds it back.
BR0NCO
Randy
Mass
Jeep Audi
I don’t think it will ever be made to tow that much more, it’s just not one of the attributes of a Bronco, just like a Mustang GT or hot air balloon won’t ever tow 7500 lbs.
