Dog approved bronco steps, stairs, ramps, carriers
Ground_zero298
Scs michigan
I’ve seen a lot asking what steps or ramps others are using for the bronco.
I went with this one off Amazon for Reign when she tore both her acl’s. It’s easy to use, doesn’t weigh to much, takes up minimal space. Dog uses it but doesn’t seem to love it. I like it because I can stand next to it to guide her.
If you do the grab the handle and drop to extend method, you could hurt your foot. Only possible issue I see with them. She got up to 100lbs and they worked just fine for her.
https://www.amazon.com/gp/aw/d/B08DN8R56J?psc=1&ref=ppx_pop_mob_b_asin_title
arielclaire0117
Ariel
Sisters, Oregon
2023 Big Bend 2 door
ive been looking for this! where did you get that bed? did you end up doing the seat delete?
Ground_zero298
Ground_zero298
Scs michigan
I did remove the rear seats. I went to the local upholster shop and had them measure and make the cushion for the back.
arielclaire0117
Ariel
Sisters, Oregon
would you mind telling me those measurements for the bed?
