Driving experience with Sasquatch gearing and 33" Tires?
86EddieBauer
Maryland
2003 Impala
Im thinking of going Sasquatch for the lockers, but want to use it as a daily driver for a few years.
What would driving be like with the 2.3L Engine and 4.7 gears and smaller (32" or 33") tires?
High RPMs at any speed? Horrible Gas Mileage? I have seen the gear/rpm calculator, but Im thinking about overall drivability.
Thanks
MaverickMan
Shane
Probalby scoots. Would definitely help the 0 to 60 times.
uncledoodoo
Everglades
00 XJ, 56 F100, 11 Volvo XC90, Everglades
Everglades
Thanks
should be very quick and torquey. I believe 6th and 7th are both overdrive so shouldn't hurt mileage too much.
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Any sas unit is going to suck gas. What is your definition of bad.
Rick Astley
Up Doug's ass
d
Thanks
Badlands 2.3/MT has the Samscratch gearing on the 33" tires.
If you can find a Badlands MT to drive you can experience it yourself! (tall order, just trying to inspire you!)
Ford Bronco Driving experience with Sasquatch gearing and 33" Tires? Bronco gearin
86EddieBauer
Maryland
2003 Impala
Rick thats a good point about the Badlands 2.3/MT. I'll keep an eye out for a dealer mannequin or badlands MT review.
hemiblas
Roger
Aurora, Co
17 mustang gt, 3 Wrangler JLs
Yep, it'll scoot....Keep in mind that there is also a big difference between 32 and 33" tires as well....32s are generally 1 inch less width and height....so they are generally much lighter than a 33. I might throw 33s on my 2 door squatch just for fun to get a little extra speed out of it too. I bet the mileage stays the same as the tire will weigh less, so you have less rotating mass, but a few more rpms due to the smaller diameter.
You will want to reprogram the speedo though as it will read wrong and will register more miles than you actually drive.
Corsair
Jacob
San Francisco
Escape
The gearing of the manual and automatic transmission are different, so I wouldn’t count on that giving an equivalent feel on drivability.
