Driving without bedlock beauty rings installed? And torx bolt size?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
No. I'd rather struggle with something that is moderately close. :ROFLMAO:
TBH, I don't even know if I have a regular Torx bit. My tool assortment is limited right now.
I’m a tool junky, so I have sets for both. Made in the USA, and pretty reasonably priced, at least south of the border.
Ford Bronco Driving without bedlock beauty rings installed? And torx bolt size? 59CB7467-2637-42D1-931F-561072AC4DA2
Ford Bronco Driving without bedlock beauty rings installed? And torx bolt size? 47AD5BC2-9A2D-459E-B057-66029CE02279
cmcbronco
Illinois
2012 f-150 FX4
I broke mine loose by hand then used an impact to get them off the rest of the way. They were tough to remove and my bronco only has 40 miles on it. Can’t imagine if you’ve been driving for a while with salt and whatnot. T45 fit perfect for me and none of them stripped. Hopefully have the same luck reinstalling.
WuNgUn
Ontario Canada
2 door Squatched
Yes you can drive around without them on. I did, while mine were being powder coated.
Just be careful removing the bolts. I stripped two and each bolt was $25 CDN from Ford (thankfully I got them slightly cheaper, but still…).
$25?? No wonder the Squatch option was so much!
12 per wheel, 5 wheels is $1500 😂😂
WuNgUn
Ontario Canada
2 door Squatched
Definitely, DEFINITELY reinstall them back in with antiseize. Aluminum and steel don't get along well
vrtical
Doug
GSMNP, TN
Fords
Not trying to hijack this but we installed rings on a new unit and had to drill 6 of the mother f'ers out due to round off. Couple things we've noticed. One, the socket isn't deep enough for a Torx. Two, the major problem these are difficult to extract is because of the yellow Loc-Tite applied to the bolt from the factory. Three, steel bolt, aluminum ring, aluminum wheel, frequent exposure to water, road salts and chemicals. Tell me, metallurgists, what do you think is going to happen in 6 months when you want to take them off?
I'm trying to find aftermarket replacements since $12.00/ea, 12 per wheel, isn't going to cut it. Button head, M 10X1.5X25. Head is 16.3mm wide and just under 5mm high. The recess in the ring is approx. 17mm wide so the standard bolts I've seen that are 17-17.5mm wide, aren't going to work. These really need to be some flavor of stainless that can be coated/plated black. Ready, set, go!
its as bad as Fords lug nuts...
mykoljay
North NJ
2021 Bronco 2DR
Well, I'm glad I removed them before putting miles on them (so maybe that's why it was easy enough). In fact I have the sasquatch wheels and waiting for my bronco! (bought them off a forum member)
B Miller
Sherwood, OR
I need to get the beadlock rings on my sasquatched Bronco powder coated. This may take a few days.
Question: Can I drive without the beadlock rings on......just around town?
lrdraca90
Ohio
Yes. You can drive around town. Standard Sasquatch ring is a beauty ring.
