- Aman
- Jul 6, 2020
- 5
- 1,469
- 4,047
- Northern NJ
- 1998 M3, 2008 Armada, and 2022 Badlands ManSquatch
- Badlands
Did you have any fitment issues with the AAL gear? My battery holder and Redarc mount sit too high to close the cover. AAL hasn't offered any solutions. I ordered their 2 Door Bronco MASS Plus Platform hoping it will solve my issues.Here is where I ended up. I ran 4 AWG wire from the Blue Sea cut-off switch in the engine bay to the REDARC charger under the cargo floor. Then used 8 AWG wire to run four Dakota Lithium batteries in parallel using a bus bar. Ran that behind the driver’s side panel to the Dometic hardwiring kit, which I mounted on the pop-out panel that covers the bolts that secure the soft top. The panel is sticking out in this photo, as the bolt holding the kit is too long and hits the molding behind it. With a shorter bolt, it should clip back in completely. I plan to add a voltmeter to that same spot. Everything was doable with a buddy over two Sunday afternoons, multiple Amazon deliveries, and several visits to both Home Depot and Ace. The wire does create a bit of a bump in the floor, but it’s not bad. Would love to swap out the floor for a Goose Gear with a fridge slide at some point. Thanks to American Adventure Labs for the solution.
