- Josh
- Apr 25, 2022
- 375
- 532
- 179
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
DV8 Off-Road SPBR-01 Steel Front Skid Plate Fits 2021-2022 Ford Bronco
The DV8 Bronco Front Skid Plate was designed to work with both the original OEM bumpers or our aftermarket Bronco bumpers. If your Bronco has the factory plastic skid plate, this is the perfect upgrade to maximize the protection to the front undercarriage. It also protects the sway bar disconnect on the Badlands and First Edition trims. Made from 3.5mm Steel Plates & 5mm Steel Supports, it can handle anything the trail throws at you! Key Features: Micro-Texture Black Powder Coat Protects Front Underbody Constructed from 3.5mm Steel Plates & 5mm Steel Supports Paintable Aluminum Mesh Inserts Easy Bolt-On Installation
