- Mar 17, 2022
- 83
- 224
- 398
- Riverside, California
- Website
- dv8offroad.com
- Bronco's & Jeep's
- Badlands
2021-22 FORD BRONCO | OE PLUS SERIES SIDE STEPS
The OE Plus Series Side Steps for the 2021+ Ford Bronco were designed to offer an easier step up into your cab and provide light protection on the trail. These are perfect for those who will be running their Bronco as a daily driver, especially if you’ve given your Bronco a lift. The 2mm thick steel tube supports are topped by 3mm & 5mm thick steel plates with bike pedal-like teeth to provide sure footing when entering or exiting the cab.
Check them out here: https://dv8offroad.com/products/bronco-side-steps-oe
Key Features:
- 2mm Tube & 3mm Plate High Strength Steel
- Micro-Texture Black Powder Coat Finish
- Engineered for all 4-Door Bronco Trims
- Easy Installation Using Provided Hardware
- Fitment: Direct Fit
- Finish: Micro Texture Black Powder Coat
- Material: Steel
- Material Thickness: 3-5mm Plate/2mm Tube
- Weight: 63lbs
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
