Seems low considering those rails are connected to hardpoints and not directly to the roof. Am I interpreting this spec incorrectly?
Agree that it is a low rating. A clamshell Rooftop tent normally wieghs over 110lbs. Hope there are better options to increase the dynamic load. Carry. Static is like 400 which is ok.Seems low considering those rails are connected to hardpoints and not directly to the roof. Am I interpreting this spec incorrectly?
Garage clearance?What’s the logic behind not offering a rack with the 35” tires? What does one have to do with the other?
This^^^^I think this is just for the panels, I would think when a rack is noted it will be higher for the rack.
I hadn't seen that anywhere, but if true likely for the reason someone else said. Rollover riskWhat’s the logic behind not offering a rack with the 35” tires? What does one have to do with the other?
That's not what those figures mean.This^^^^
The 110lbs is ONLY for the panels. The rails have the 450+lb rating
