Dynamic Roof Load limit of 110 lbs
BoatBuilder88
New Jersey
2019 Wrangler
Seems low considering those rails are connected to hardpoints and not directly to the roof. Am I interpreting this spec incorrectly?
MadMan4BamaNATL
Ray
Atlanta
Agree that it is a low rating. A clamshell Rooftop tent normally wieghs over 110lbs. Hope there are better options to increase the dynamic load. Carry. Static is like 400 which is ok.
aplm7
Andy
Vacaville, CA
2023 Bronco Wildtrak 2 door
Where's that info from? Likely has to do with the amazing suspension being so good for speed
WuNgUn
Ontario Canada
2 door Squatched
Just legal mumbojumbo...
My Escape with a sunroof has a roof capacity of 50lbs, while steel roof models it's 100lbs.
Why? Highway rollover... That extra glass in the roof changes the COG and dynamics of the car.
Ford just doesn't wanna be sued for you crawling and rolling over with 400lbs on your roof.
jtzako
Jason
Xterra Pro4x
110lbs maybe tricky. Just a quick look on REI and only 2 of theirs would work (both 2 person and under 110lbs). The 3+ person tents all are well over the 110lb.
Blksn955.o
Greg
Wentzville, MO
I think this is just for the panels, I would think when a rack is noted it will be higher for the rack.
Sammy7
TBD
What’s the logic behind not offering a rack with the 35” tires? What does one have to do with the other?
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
Garage clearance?
FirstOnRaceDay
Devin
Toledo Ohio
This^^^^
The 110lbs is ONLY for the panels. The rails have the 450+lb rating
AK SNO RIDER
Ty
Alaska
I hadn't seen that anywhere, but if true likely for the reason someone else said. Rollover risk
BoatBuilder88
BoatBuilder88
New Jersey
2019 Wrangler
Rollover risk is definitely a reasonable guess. Based on the published specs, it's not garage clearance. (this was my original assumption)
Marauder
Josh
St Louis
Damnit, I told my neighbor’s kids that they won’t be able to ride in it, but I was going to strap them to the roof.
#cancelCulture
lobbs611
Kyle
Independence, MO
2D JL Rubicon
This^^^^
That's not what those figures mean.
Dynamic at 110 pounds is what they can handle while the truck is in motion i.e. gear shifting around while you're out on the trail.
The 450 lb Static rating is if the truck is parked.
For example, you find a roof top tent that's less than 110 lbs. You're cool to ride around all day out on the trail with minimal risk of damage to the top. But, once you decide to go to sleep that night you've only got 340 lbs of capacity to put up there (450 minus the 110 lb tent). Camping by yourself not such a big deal but bring a friend or a pet, your bedding, any gear you want safe up there with you and it eats into that 340 lbs pretty quickly.
There are several companies that make bracing for the inside of Jeep tops that tie into the sport bars and side rails and even more that make an exoskeleton type rack. Those will get ya to 300-400 lbs dynamic and 900-1000 lbs static which is plenty of safety margin if you're doing any kind of real roof top tent camping. I'm sure something similar for the Bronco will come soon enough. Personally, I'm trying to decide between one of these beefed up tops or just building a 4x6 off-road trailer with a rack for an RTT. The advantage of the trailer being I can park it easily when I'm not camping. MPGs may be a wash between a RTT mounted on top of the truck or a slightly heavier trailer but at least in the slipstream on the truck.
Fordboi
Cameron
Murica
1966 Ford Ranchero
i guess no putting old kona dh bikes on there then lol. anyone whos tried to ride these up a hill will know what i'm talkin about
