- Austin
- Sep 27, 2020
- 46
- 996
- 1,567
- Houston, Texas
- 2019 Subaru Crosstrek
- Base
I spoke with a couple of techs at a Christian Brothers location and they mentioned two issues with EcoBoosts to be aware of.
The first was the 2.7L plastic drain plug and how it needs to be replaced every other oil change or it'll leak. I knew about this one. @Rick Astley recommends buying a metal fitting and drain plug that seems to convert it to a regular drain plug. Perhaps others have thoughts on this as well.
The other issue was the proprietary coolant hose coupling / T-fitting. It's a kind of quick disconnect instead of regular hose clamps. They said most EcoBoosts leak when it isn't under pressure, meaning when the vehicle is off. It tends to drip on a hot surface instead of right on the ground and doesn't make a pool under the vehicle in your garage, but to watch coolant levels and top off occasionally.
For those that own a 2.7L or other EcoBoost, have you heard of these problems and if so, what's your solution? Thank you.
