ECU tunes for Bronco Raptor
Tye
Tye
San Francisco
Porsche GT3, Range Rover P525, Audi Etron Chronos
will this void the ford warranty, and if so is Whipple offering any type of warranty?
Lastly, what is the package cost?
HaugenRacing
Scottsdale, AZ
2022 Ford Bronco Raptor
As I posted prior, Ford significantly beefed up encryption on this ECU, likely just more bits, and it's unlikely to be cracked. They want the money going to tuners today (or at least a share of it).
SCT will crack it. Just talked to them. They're working on it.
swamp2
"Crack" as in send in yours and have it literally unsealed and a tune uploaded or cracked generically so any tune can be written to anyones vehicle? I wouldn't be so confident in the latter.
HaugenRacing
Scottsdale, AZ
It will be a handheld you can upload tunes to the ECU with. Just like the always do. No sending ECU in. I meant cracking as in breaking through the software security.
swamp2
Familiar with the article I posted prior in this post?
swamp2
Well, GM also claimed their new Global B architeture in the the C8 Vette is "essentially hack proof" but it was cracked.
Not sure the Braptor market is as large as the C8 market.
Here's to SCT hoping they can do it.
FLSTFI Dave
East TN
2018 Grand Sport, Carbon 65, 2017 F-150
Nice job with tat tune. Will this void the Ford warranty?
Ground_zero298
Scs michigan
Power will be capped until the ecu is cracked. 2.7 is around 450 whp max right now with the fuel delivery as it is. 3.0 will make more.
Every tuner is working on cracking the ecu. For the last 2 1/2 years.
For the 2 door 450whp is just about right. Thinking braptor will have to be over 500 to keep up. I’d guess braptor will come in around 550 maxed for general bolt ons and tune.
Finbox
FL
KLR650
Is the STOCK running 87 gas?
Why is the STOCK pull started at 2200rpm? The others have more time to generate boost when they start their pulls at 1700 RPM
Ford Bronco ECU tunes for Bronco Raptor 1679924914922
Tye
Tye
San Francisco
Spoke to COBB today, they have no plans to provide an Accessport for the Bronco Raptor either.
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
That sucks, guess we shall see if Ford Performance come out with one. if not sure I will tune since there is no way to switch back and forth with the Whipple.
switz
Nevada City, Ca
2022 Bronco Raptor, 2022 Bronco Bad Lands
Any idea if the Whipple Tune will be 50-state compliant for smog/emissions testing? I would only want to write the ECU once with the Whipple and not go back and forth every time I need to get the vehicle smogged.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
After talking to someone at ford performance it seems very unlikely ford will create a tune for the Braptor.
Tye
Tye
San Francisco
CARB is pending on it
