This is what I have done and I am extremely happy with the setup. I ended up going with the preset height of about 2" of lift from sasquatch height (2.25" front, 1.75" rear). Everything was still in alignment, but I definitely can't go higher or camber would be out.Yes I think lowering it a bit would most likely help. I also am seriously considering this coil-over option as price/performance and what most of us need I think puts this lift in a sweet spot. I'm only looking for a 1-1.5" lift all the way around from stock sasquatch height to clear the 37's I'm running. Keeping the lift to a minimum also leaves the front upper and lower control arms in a more neutral position so the ride will be smoother overall. Right now I have some perch collars as a stop gap but I think these Eibachs will be perfect overall for those of us not doing anything super extreme.
I'd like to know your final thoughts on this kit once you have dialed it in where you're happy with it.
The ride is great. Softer than stock, but in a good way. I'll be getting it off road in February to test it out to make sure my 37's still don't rub when stuffed. From what I've been able to test so far, it looks to clear.
