Electronic Throttle Controller
FourHorses
Four Ford Horses and an Expedition
Back in the early 2000's Ford migrated from Throttle by cable system to a throttle by wire system. What this means is that instead of a throttle cable connected to your throttle pedal that connects to your throttle body, they are now ran as an electronic signal through your PCM and a voltage change adjusts the opening of your throttle body. What does this really mean to you? Well efficiency is one, but what it also means is throttle lag. You push on that pedal and your vehicle does not immediately respond for many reasons. Mostly... MPG. It was really bad and noticeable on manual transmission Mustangs from 2005-2009's. Most people fix it with their tuner, but a market has been developed for the inbetweener that doesn't want to tune their vehicle and for various reasons. The simple fairly inexpensive solution is a throttle controller. This could be a viable solution for the Bronco, auto or manual, 2.3L or 2.7L.
American Trucks has a good video explaining the purpose of the device, as well as some scientific testing to show you how and why it works. I suspect this to be an issue to some with the Bronco. What do you all think?
rtaylor
R
ID
19Raptor, 22Bronco
It is an issue on ecoboost trucks, so Bronco should be no different. But I think you might as well increase the boost with a tuner while you are at it.
FourHorses
FourHorses
I don't dispute this. Many folks are nervous about doing anything that could put their warranty in jeopardy though.
jwoobs
Detroit
The goat modes will likely remap the throttle position sensor already.
Not to mention, this won't actually make the engine respond any faster, it will just change how much you have to move the pedal to get the same amount of throttle body movement.
Personally, I wouldn't spend the $300...
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
Here's my take as I have a pedal commander in both of my trucks. It's not that useful if you aren't bothered by the lag in the pedal, other than that I think it's pretty alright, I don't know why anyone would want to have most of their throttle control in the first quarter of pedal travel but I guess that option is there if you want it. Drive modes work with the pedal commander. For example in my raptor offroad mode changes the throttle map to be linear as if it was cable driven and I'd assume bronco baja mode will do the same thing. My tremor also changes the throttle in rock crawl mode but I'm not sure how. I only have the pedal commander to get rid of the lag on the street and that's it, I'm not a fan of it being turned up and having the response turned down should be a sin.😂
FreshKsig
Ryan
Idaho
FE Bronco, 22 BB Bronco, 21 Mustang Mach 1
I had the pedal commander on my Raptor. Best $300 accessory ever.
MaverickMan
Shane
So in my cj days it was popular to put a hand throttle on the carb for setting the idle high for winching when alone or to help you walk up certain obstacles or just for simple jeep surfing shenanigans. Do these controllers have any function that allows you to set a high idle for whatever reason tickles ones fancy?
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
No. They literally just alter the voltage ramp from the pedal to emulate pushing the pedal more than you are once you start pushing it.
SPT@SolerPerformance
McAllister
Daphne, Alabama
www.solerengineering.com
05 4Runner, 21 Mustang GT Premium, 2015 C7, Bronco
