End of winter storage - oil change?
MK0412
NH
Accord and Bronco
Changed oil before going into storage for 5 months. Should I change it again after?
BigFootie
Wisconsin
Nor sure why you would. I’ve been storing vehicles over the winter months for 30 years. I stick with my standard schedule unless I’m close before storage and then I’ll do it before.
Y2KFirehawk
PA
2022 Bronco Wildtrak
Definitely not. To validate with data, I have done oil analysis reports (Blackstone) to validate the same.
JohnnyBronco
Pennsylania
X4
Only fluid change after storage to consider would be the fuel if you did not use Sta-bil or similar. 5 month old gas will be crap by now and you have a full tank. That being said, you would have parked with a completely full tank so condensation and degradation would be less than if parked with minimal fuel in the tank.
I would try to burn through that tank as quickly as possible and even consider at half full topping with higher grade than you normally run
MK0412
MK0412
NH
Accord and Bronco
wasn’t able to use fuel stabilizer. Had issues pouring it in. Don’t think the spout was long enough. Filled it up with premium fuel which is what I use regularly. Burning through the gas shouldn’t be an issue. It’s storaged in a temperature controlled location.
zuke
Stafford VA
For future events, there is a spout in your rear cubby (Where the jack is) meant for filling the tank from a gas can, You can use that to pour fuel stabilizer into the tank.
Only reason to change any fluids is if there was a possibility of contamination in those fluids (Like outside storage, or storage in a corner of a working shop with lot of junk in the air), It's sounds like the conditions you store it in are going to prevent that!
Lifeliberty
Moonbeam👀
Columbus, OH
Next time pour the stabilizer in a gas can with gas to pour it in.
Don't worry about the oil
Turner00
Jerry
Akron, OH
2023 Badlands SAS
I had the same issue with injector cleaner, you need to use the semi-transparent thin funnel stored with the jack in the back.
