Engine Bolt Pattern same between 2.3L and 2.7L?
teejayhoward
CO
BRZ
Do the 2.3L and 2.7L engines have identical bolt patterns? News of the manual transmission being restricted to the smaller engine makes me wonder if a swap is possible without a custom bell housing.
The Pope
Good question!!!!!
JimmyDean
Louisiana
Apparently not. The 2.7 shares it with the larger engines. 2.3 with the smaller ones.
DrewBronc21
New York
Iā€™m wondering same thing....buy a cheap base 2.3 manual and swap in a 2.7 hmmm. Iā€™m sure it will be done
The Pope
It the Bellhousing of the MT part of the transmission body casting or is it a seperate bolted on part?
JimmyDean
Louisiana
So what your saying is that we would be better served for 5.0L swaps if we got the 2.7?
Mmhmm. Or get 2.3 and stick and swap entire setup for 5.0/7.3 in 10 years
Fordboi
Cameron
Murica
1966 Ford Ranchero
i think a 7.3 is way to big for a bronco. in terms of displacement.
JimmyDean
Louisiana
I think itā€™s a better fit than the 5.0, lower end torque, doesnā€™t need to rev to 6k-7k rpm, and is narrower and about same weight
JimmyDean
Louisiana
Haha 10 years? How long is powertrain warranty? 5 years 60k miles?
it will have a V8 by year 3, at 60k miles.
Well, I was estimating when you blow up the 2.3 and need to replace it.
Fordboi
Cameron
Murica
1966 Ford Ranchero
yeah i thot about that right after i posted
NCOBX
H2 Hummer, Holden Commodore
Iā€™d prefer the 7.3l, but I donā€™t know if that trans would fit in place on the Bronco.
teejayhoward
CO
BRZ
Think the Bronco tranny could handle the 7.3L torque curve?
Laminar
Iowa
Cougar
The 2.7 bell housing pattern is common with Fordā€™s other V6 engines. The only manual available that will bolt up is the MT-82 from the 2011-up V6 Mustang. But thatā€™s not set up for 4x4.
The 2.3ā€™s bellhosuing pattern is common with the 2.0 and 2.3 Duratec and EcoBoost, along with Mazdaā€™s same displacement offerings since the EcoBoost was developed from the Mazda engine.
If I was V8 swapping, honestly, LS is your best bet. Short, narrow, big displacement for the package size. If you have to stay Ford, Iā€™d go Coyote. The 7.3 sounds cool in theory, but itā€™s a big heavy iron block 3/4-ton truck engine. Itā€™s sized between a small block and big block with larger bore spacing that the Coyote, so itā€™s longer front to back. Good luck squeezing the 7.3 and all its accessories into the length designed for a V6.
The Coyote is wider, but if you get creative with the headers you can fit it many places. People are squeezing them into ā€˜90s BMWs with minimal issues. The 2.7 width including turbos isnā€™t much narrower.
