Engine RPM with 35” Tires
20Bronco21
Amidst the Cornfields of Illinois
’22 Badlands, ‘23 Balands
I need some information an gearing, assuming the Sasquatch Package is ordered with the 4:70 gearing, V6 with 10 speed auto with a 0.63 tenth gear, what would the engine RPM be at 60 mph? I plan on mostly highway usage and do not need to have the engine turning 3000+ RPM to run in the 60 to 70 mph range. I have no experience with tall gears and big tires, I need some enlightenment.
Zinn
Minnesota
2016 Mustang GT, 2020 Ranger Lariat
I think it would hard to be able to estimate without better weight info -- and a tachometer :-x
Shyrax
Jason
AL
‘17 Tahoe Z71
Not sure how accurate the online RPM calculators are or my ability to use them correctly, but with the specs you listed, they are all showing between 2270-2280 RPM at 80mph.
Spooled
Republic of Texas
60mph will be under 2000rpm with Sasquatch
Nickp
Nick
Phoenix
Glorious
wvmtneer
‘Merica
F-150
MPG is the next question for Sasquatch. I can see it being 15city/19highway for the 2.7. The Bronco will have heavy tires, turbos and unfavorable aerodynamics.
Laminar
Iowa
Cougar
Here's my spreadsheet for the Bronco with the 10R80 and 35" (actual 34.4") tires.
Assuming full torque converter lockup and a true 34.4" diameter, it'd be 1753rpm @ 60mph.
Nickp
Nick
Phoenix
Oh buddy. I’m definitely going to remove the speed limiter so I can hit the 205 mph top speed ???.
20Bronco21
20Bronco21
Spooled
Republic of Texas
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
In the available factory configurations, 35's provide the most smiles per gallon.
