- First Name
- Andrew
- Joined
- Mar 7, 2020
- Threads
- 16
- Messages
- 4,895
- Reaction score
- 8,431
- Location
- North Carolina
- Vehicle(s)
- 2021 Ford Bronco
- Your Bronco Model
- Badlands
Thanks for the detailed reply! KC does make brackets now but the mounting hole has to be drilled out a little to fit Daylighters.I'll ask if he'll make more brackets, I knew it was going to come up. He said he would prefer to make them out of aluminum but mine were made with steel, and then pickled, and then painted with engine block paint. He nailed the machining based on a cardboard template he made, but he's an experienced machinist so I'm not really surprised. The intent was to keep them clear of the hood and mirrors if they were folded forward, which they are.
KC has supposedly been designing/planning these brackets for the Bronco for months, but there's no update on when theirs will available. Meanwhile, mine went from design to fabricated to installed within four hours.
And yes, there's an antenna hole. I did an antenna delete since I use carplay, but I have my antenna hidden in the the back just in case I ever need it.
Also, for what it's worth I ran these to Aux 3 which is a 10A switch, each KC 651 says to pull 1.63A each but I wanted to be safe so I put them on the 10A circuit. I could have put them on a 5A circuit just as well but didn't feel it was necessary. I'm adding a winch which will be either Aux 1 or Aux 2 but other than that don't have any plans for anything else with higher power draw.
For reference, the AUX amperage and wire color per switch is as follows-
Aux 1- 25A (Yellow)
Aux 2- 15A (Green/Brown)
Aux 3- 10A (Violet/Green)
Aux 4- 5A (Brown)
Aux 5- 5A (Blue/Orange)
Aux 6- 5A (Yellow/Orange)
Here's another picture-
