Expected axle gear ratios & what ratios are you hoping for? (dependant on engine & tire choice)
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
So with the new info I used 6.5 crawler first, 2.72 transfer case F-150, and a 4.7 final gear comes in at 83.1 crawl ratio in my calculator. Right in the Rubicon range. (y)(y)
I BET there will be a lower transfer case optional for higher trims
BAUS67
redneck
Central PA
Well in that case, since you brought it up, if I use the Rubicon's 4.1 case, which is also the same as the Atlas commonly use in the off road world, ……………… it's a staggering 125.3 !!!!!!
........so at the least the base Bronco has a crawl ratio on par with the Rubi's (y) (y)
JimmyDean
Louisiana
82 Bronco, 513 ci; 71 mach 1, 351C; 06 F-250, 6.0; 56 800, 172c.i. gas
at that point I could set it to holdmax RPM and still walk beside it....
BAUS67
redneck
Central PA
Bimmerxi
Ford Ranger, BMW R1200GSA
Going to try to revive this since most of the talk was before the specs came out I’m considering a black diamond with the seven speed and 2.3. It’s gears on that are 4.46, looks like badlands with 33” tires is 4.7. If I wanted to mount 33” is the 4.46 enough? One would think so? Might mess up the creeper gearing?
BAUS67
redneck
Central PA
7MT, 4.46 rear, and Advance 4X4 transfer case is a crawl ratio of 89.1
7MT, 4.7 rear and Advance 4X4 transfer case is a crawl ratio of 94.75
now that we know the numbers to put in my calculator.
