Fabtech 2021 Ford Bronco 4WD 3in Uniball UCA System w/DL 2.5 Resi Coilovers & Rear DL Coilovers now available!
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
Fabtech’s high-quality Uniball UCA lift kit for the Bronco offers increased front suspension travel for enhanced offroad capabilities with clearance to run 35" tall tires. The stance of the vehicle with this kit will become more level front to rear for an aggressive look.
The factory Bronco upper control arms are replaced with Fabtech’s Uniball Upper Control Arms that provide additional wheel travel with an extra degree of caster compared to stock arms. The increased caster helps to balance steering effort with oversized tires.
The Fabtech upper control arms are constructed of the finest material with .120" wall 1.25" OD 4130 Chromoly steel tubing. High-quality 1" FK Stainless PTFE lined Uniball bearings are utilized in place of the small factory ball joints and allow for increased travel without bind. These super stout Bronco upper control arms are designed for longevity in rugged offroad conditions while providing a more positive on-road feel.
The Fabtech upper control arms have been designed to work in conjunction with the Dirt Logic 2.5 Coilover shocks to provide additional front wheel travel.
The rear suspension receives Adjustable Lower Link Arms with Fabtech’s lifetime 5 Ton joints®. The lower links are .313 thick wall tubing that are guaranteed never to bend. Dirt Logic 2.5 Coilovers are utilized for a balanced ride front to rear.
This system is perfect for those that want increased suspension performance with a low lift height. A great choice for daily drivers that want a clean look with the ability to hit the trails on weekends.
You can purchase this as a full kit, or indvidually:
Full Kit: https://www.pandamotorworks.com/collections/suspension/products/fabtech-2021-ford-bronco-4wd-3in-uniball-uca-system-w-dl-2-5-resi-coilovers-rear-dl-coilovers
Front & Rear Coilovers: https://www.pandamotorworks.com/pro...ir-coilovers-pair?_pos=3&_sid=e646cafba&_ss=r
Uniball UCA System: https://www.pandamotorworks.com/pro...niball-uca-system?_pos=2&_sid=e646cafba&_ss=r
Lower Link Kit: https://www.pandamotorworks.com/pro...co-lower-link-kit?_pos=1&_sid=e646cafba&_ss=r
**We expect these kits to ship January 2022**
FEATURES
  • Arms eliminate upper ball joint w/ super strong 1" ID Stainless American Uniball
  • Chromoly tubing reduces flex found in stock arms for a more positive road feel
  • 17-4 Stainless Steel Heat treated Uniball pin fits into factory ball joint taper without modification to the spindle
  • Adjustable lower rear link arms for increased strength & articulation
  • Front & Rear Dirt Logic 2.5 Coilover Shocks
  • Great system for the daily driver that requires increased offroad performance
  • 5 Year 60,000 Mile Powertrain Warranty
Fits 4-door models only
Full Kit:
Ford Bronco Fabtech 2021 Ford Bronco 4WD 3in Uniball UCA System w/DL 2.5 Resi Coilovers & Rear DL Coilovers now available! k2378dl-kit_704x480
Front:
Ford Bronco Fabtech 2021 Ford Bronco 4WD 3in Uniball UCA System w/DL 2.5 Resi Coilovers & Rear DL Coilovers now available! k2378dl-ww-front-640x427_640x427
Rear:
Ford Bronco Fabtech 2021 Ford Bronco 4WD 3in Uniball UCA System w/DL 2.5 Resi Coilovers & Rear DL Coilovers now available! k2378dl-ww-rear-640x427_640x427
rtaylor
R
ID
19Raptor, 22Bronco
I am interested, but it is not clear yet if these are simply an alternative to 4WP for upgrading non-SAS models or will offer competitive specs. Unfortunately, many of the Fabtech coilovers do not have any published length specs (like 4WP). If they won't publish specs like the big players, I won't be considering them.
