Advertisement
FAQ's I'll attempt to answer with official Ford responses
Bronco Dealer
U.S.
Explorer ST, Escape SE, JK Sahara
I'll post updates as fast as possible for you, but keep in mind, there are some things that dealers are not allowed to share.
How much will it cost to reserve a Bronco? Reservations will cost $100.
Is the $100 refundable? Yes, automatically with reservation cancellation.
Will reservations be fulfilled in the order placed? Reservations will be fulfilled in approximately the same order received, based on final ordering and production of similarly configured Broncos. All reservations will be completed before production of stock units begins.
Can customers “game” the reservations by ordering more than one? Customers will be limited to no more than two reservations per ford.com customer account.
When will customers be able to finalize their reservations? Reservations open on July 14th and will be finalized when customers complete the process with your dealer; that’s expected to be July for Bronco Sport and December for Bronco.
Can customers update their dealer selection for their reservation? Customers can reach out to Ford Customer Support for assistance should they need to change Dealers.
Tell me about the all-new Bronco models. The all-new Bronco two-door and first-ever four-door models are the flagships of the all-4x4 Bronco brand family of vehicles, ready to deliver thrilling experiences with heritage-inspired style, smart off-road technology that provides the goes-over-any type of terrain (G.O.A.T.) confidence to tackle tough terrain, plus ingenious human-centered design insights to elevate all-levels of outdoor enthusiasts adventures.
What are the trim series for Bronco two and four-door models? Bronco will be available in seven series at launch. These include Base, Big Bend, Black Diamond, Outer Banks, Wildtrak, Badlands and a First Edition. There will also be an available Sasquatch package on all series for owners who want even more Bronco capability.
What comes with the Sasquatch package? This package includes 35-inch-diameter mud terrain tires on 17-inch black high-gloss alloy beadlock-capable wheels, electronic transfer case, electronic-locking front and rear axles with 4.7:1 final drive ratio, high-clearance suspension that adds up to 1.2 inches of extra lift (1.0-inch front, 1.2-inch rear) and larger fender flares, and heavy-duty position-sensitive Bilstein shock absorbers. Sasquatch, which comes standard on Wildtrak and First Edition, can also be specified for every other Bronco model.
What ground clearance is improved by adding the Sasquatch package? With up to 1.2 inches of increased lift, plus larger 35-inch diameter tires, the Sasquatch equipped Bronco two-door improved 3.2 inches to 11.6 inches of ground clearance (up from 8.4 inches) and on fourdoor models, 11.5 inches of ground clearance (up from 8.3 inches).
Which design cues does the all-new Bronco take from the first-gen Bronco? The all-new Bronco pulls a number of design cues from the first-gen Bronco, including iconic proportions and character lines, round LED headlamps, encapsulated grille, offset cluster, and swing gate
with full-size tire. In fact, our design team digitally scanned a first-gen Bronco to stay faithful to its iconic proportions and looks.
How much will Bronco cost? Bronco will have a starting MSRP of $29,995 (including destination and delivery). Customers can reserve one today for $100 at ford.com.
Which architecture is the Bronco two- and four-door based on? The all-new Bronco two- and four-door models feature a Bronco-variant of Ford’s new second-generation global midsize truck architecture. This even more rugged and off-road capable architecture is similar to
the Ford Ranger and built alongside the midsize truck at Ford’s Michigan Assembly Plant.
When does Bronco go on sale? Bronco will start arriving in dealerships next spring.
What is Built Wild Extreme Testing? As a notch beyond the Built Ford Tough truck cycle, Bronco engineers add additional series of testing in the high California desert of Johnson Valley, utilizing several trails, including the King of the Hammers brutal off-road competition terrain
to help make Bronco better, stronger and ready to outperform for years to come.
Which engine options will Bronco have? Bronco will be available with a standard 2.3-liter EcoBoost engine and available 2.7-liter EcoBoost.
Which transmission options will Bronco have? Bronco will be available with a SelectShift 10-speed automatic transmission and a segmentfirst 7-speed (6+1) manual transmission features a unique class-leading crawler-gear ratio of 95:1 to help travel over challenging off-road
terrain at low speeds
Is the manual transmission available on the 2.7-liter EcoBoost? Will it come later? No. We have specifically designed the Bronco sevenspeed manual application for the 2.3-liter EcoBoost engine.
Is the manual transmission available on both two- and four-door models? Yes.
Is the 2.3-liter EcoBoost the standard one or the Mustang’s High Performance Package unit? The Bronco has its own version of the standard 2.3-liter EcoBoost engine. While sharing parts at the engine’s core, the engine has been developed and equipped to deliver on the Built Wild Extreme Testing cycles that ensure confidence in grueling off-road conditions.
How much horsepower and torque will each engine have? The 2.7-liter EcoBoost V6 produces a projected 310 horsepower and 400 lb.-ft. of torque and a 2.3-liter EcoBoost four-cylinder produces a projected 270 horsepower and 310 lb.-ft. of torque.
What are the final drive ratio options for Bronco? Bronco is available with four different final drive ratios: 3.73:1, 4.27:1, 4.46:1 and 4.7:1.
Which type of front axle does Bronco use? Bronco comes with an independent front suspension (IFS).
Why did Ford go with an independent front suspension? Bronco is the future of off-road, and to deliver the best combination of off-road capability and comfort, an independent front suspension (IFS) is the best solution. Additionally, an available disconnecting front stabilizer bar provides additional wheel travel over challenging terrain.
What about the rear suspension? The all-new Bronco has a five-link solid axle rear suspension optimized off-road performance across a wide variety of terrains.
Is Bronco meant for more high-speed driving and not rock crawling? Bronco is meant for all types of off-road driving, including rock crawling and high-speed off-roading. It’s engineered to excel especially at higher-speed off-roading – such as over 5 mph.
Which wheels and tires will Bronco be offered with? Bronco will be available with segment-first 35-inch off-road tires from the factory on every trim series, plus available beadlock-capable wheels allow every customer to elevate off-road capability regardless of price point to access key off road features.
Does Bronco come with a stabilizer bar disconnect? Yes, Bronco offers an available stabilizer bar (Sta-Bar) disconnect system with a class exclusive hydraulic design that allows the bar to disconnect under load as well as deliver the maximum articulation and increased ramp angle index for off-camber terrain.
You say Bronco delivers class-leading off-road capabilities. What is the ground clearance? Approach angle? Departure angle? Breakover angle? Bronco has a max ground clearance of 11.6-inches, a max approach angle of up to 43.2-degrees, a max breakover angle of up to 29.0-degrees, and a max departure angle of up to 37.2-degrees.
What is Bronco’s water fording capability? Bronco has up to 33.5-inches of water fording capability thanks to its high air intake placement.
What brand of shock absorbers does the Sasquatch package have? Bronco two- and four-door models offer heavy-duty long-travel position-sensitive Bilstein dampers with end-stop control valves at every corner are available for added off-road durability and reduced harshness.
How much suspension travel does Bronco have? Bronco two- and four-door models offer up to 9.4 inches of suspension travel in the front, and 9.7 inches in the rear. Suspension travel varies between suspensions and tire size.
What’s Bronco’s max towing rating? Bronco can tow up to 3,500 pounds. What is Bronco’s max roof load rating? Bronco two- and four-door’s hard-top roof rail system can support up to 110 pounds of gear when driving. For those who will overland, the vehicle can support up to 450 pounds parked.
What is Bronco’s max payload? Bronco two door can carry up to 1,170 pounds. The four-door model can carry up to 1,370 pounds.
Which exterior body panels are removable on Bronco? The doors and roof are removable, each within minutes. On four-door models, there is dedicated on-board storage for all four doors.
Why are the doors only on the four-door stowable on board? Given the two-door model’s longer doors for easier entry and exit, the doors can’t be stored in the cargo area without folding the rear seats like the four-door. [Doors should be stored vertically to avoid damage.]
Do the mirrors need to be reattached to the vehicle when the doors are removed? No, the sideview mirrors are mounted to the body, further improving door removal and install compared to competitors. This design also ensures on-road compliance, allowing driving with doors off and maintaining side and rear visibility.
Does the Bronco two-door and four-door have a removable roof? Yes, Bronco four-door has four removable sections to give all passengers the open-air experience. The Bronco two-door’s hardtop has three removable sections standard, with four removable sections included with the modular roof option. The modular roof option also includes removable rear quarter glass.
Are there both hard and soft-top options? Yes, Bronco four-door models will have both roof options, while the Bronco two-door model will come with a standard hard top.
What is G.O.A.T. Mode Trail Management? G.O.A.T. Mode Trail Management is the system of selectable drive modes that help Bronco drivers navigate any type of driving condition. Up to seven modes are available, including Normal, Eco, Sport, Slippery and Sand, with Baja, Mud/Ruts and Rock-Crawl for off-road driving.
Which technologies does Bronco offer? Bronco offers a segment-leading available 12-inch touchscreen with next-generation SYNC 4 communications and entertainment system is available and enables connected services and class-exclusive FordPass Performance App with
Off-road Navigation for advanced trail navigation and features, plus sharable mapping, images and breadcrumb waypoints. An available class-exclusive 360-degree camera with off-road views is like having a virtual spotter to watch the terrain and contact at every wheel. Bronco will also have Over-the-Air Update capabilities.
Which safety features does Bronco offer? Bronco safety features include a modern high-strength steel roll cage with integrated side curtain airbags in the upper structure and seats helps protect passengers from side impacts and complements driver and front passenger
airbags. Class-exclusive standard rear seat (Outboard Positions) seat belt pre-tensioner. Advanced active safety and driver-assist technologies along with ABS/traction control systems are built into every Bronco to meet or exceed global crash safety requirements and build driver confidence.
What is the Trails App? How many trails will be available? Can I download trails? The system is a game changer and will be powered by class-exclusive trail content from FunTreks, Trails Offroad and NeoTreks. We’ll share more information on Bronco’s advanced trail navigation and topographic/trail maps closer to launch.
What is Trail Turn Assist? To improve maneuverability off-pavement, Bronco can brake the rear driver or passenger side rear wheel to pivot the vehicle and tighten its turning radiuses through torque vectoring.
What is Trail Control? For more precision off-road, and the ability to stay off-throttle during bumpy maneuvers, this technology provides an off-road cruise control for consistent, low-speed trail driving.
What is Trail One-Pedal Driving? For acceleration/braking control, Bronco can leverage the accelerator solely for more precise and confident slow-mode rock crawling.
Does Bronco have front and rear locking differentials? Yes. Both of Bronco two- and four-door models’ 4x4 systems are available with front and rear e-lockers for improved traction over rough terrain.
How many auxiliary switches will Bronco have for aftermarket items? Bronco has six auxiliary switches for easy connection of off-road and interior accessories.
What are Bronco’s fuel economy numbers? We share closer to launch, after we’ve received EPA certification.
Can you wash out the interior of Bronco? Yes, Bronco offers washable rubber floors with up to six passive and four active drains and available marine-grade vinyl seating surfaces that resist mildew.
Which accessories is Bronco launching with? Bronco is launching with more than 200 factory-backed aftermarket accessories for more capability, personalization and style.
Advertisement
Bronco Dealer
Bronco Dealer
U.S.
  • Thread starter
  • Thread Starter
  • #2
Sorry Hit save before I was done editing...
93_SVT_3503
Jeremy
NEBRASKA
Ford Excursion, 1967 Bronco Halfcab, 1993 Mustang Cobra, 1967F250 Hiboy
Great info from an actual reputable source, thanks @Bronco Dealer. Maybe Doug (@Administrator) should pin this post to the top of the page. This place has gone to shit in the last week. It's like cousin Eddie showed up with all his kids and they're just wandering around asking random questions instead of looking at what info Ford has given us. Can we double the size of the search bar and put flashing lights on it so these yum yums can find it?
rmc523
South Florida
2009 Ford Flex; 2018 Mustang GT
Vehicle Showcase
This info appears to be the same as that leaked dealer PDF from a few weeks ago, but nicely typed out. Certainly answers some questions.
I agree with you to an extent - I just posted in another thread the question of how many different threads do we need to ask the same 3 questions.
rmc523
South Florida
Vehicle Showcase
need clarity on HOW FLAT the 2 door seats fold.
This isnt fold flat in my opinion
That's a preproduction model.......the interior finishes aren't what we'll actually see - it's possible the seats just aren't working correctly and/or the front seats are too far back.
eatworksleepdie
Anthony
Detroit
15' Renegade, 20' Wrangler, 92' VW GTI
On the 4 door with roof rack, can you remove the roof panels while keeping the roof rack? eg., could I leave the rack on for my MTB's and take off the roof panels? It'd be sweet to have the open air (no roof) but have the bikes still up top!
Bronco Dealer
Bronco Dealer
U.S.
  • Thread starter
  • Thread Starter
  • #8
This is from a brand new PDF. Someone else had scanned a copy and posted it, I copied the text and made it a little clearer.
Also, if anyone needs to reach me, I'm not able to answer PM's, not sure why.
rmc523
South Florida
Vehicle Showcase
Oh I know - I said it was nice to see it displayed out clearly. Wasn't meaning it as a criticism.
Imprezive
SoCal
Ducati Mulitstrada
Does the Lux package have lane centering steering ala Tesla autopilot or is it just lane keep that steers you back in if you drift?
Dads_bronze_bronco
08 JKUR / 00 TJ
Since a Badlands with MT has 4.7 drive ratio M210 and M220 locking diffs, and position sensitive Bilstein shocks, besides wider beadlock capable wheels and 315 tires, what specifically does the Sasquatch package have that a Badlands Bronco without Sasquatch have?
Spooled
Republic of Texas
2017 F-150
Sasquatch package lists "high clearance suspension" seperately than the Bilstein dampers so there has to be something different. Hopefully it's cleared up soon
Jk89
Jon
Chicao
Fj cruiser
I really hope it has lane centering as an option! I need that feature
Advertisement
Advertisement
