Feedback on practicality of washout floors ?
mdepll
mike
toronto
sorento
Anyone have video or feedback on practicality of washout floors ?
Charky
Duane
Little Rock
A7
da_jokker
Jeep Wrangler JKUR
It's probably about as feasible as it is about storing doors in the back. It's all great marketing, but in reality it'll never happen.
nhbronco
Erik
New Hampshire
Toyota Sequoia, F150, Ranger, Roadtrek Agile
I had a bunch of mud in mine and the washout floors were great. I used low pressure and a brush to get the majority of it out. Then rags and a cleaner to get rid of the rest. So much easier than dealing with cleaning a rug (which I would likely have needed to do even with husky/weathertek floor liners).
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
The practicality is not having carpet in an off-road vehicle. Well, except for the carpet in the back 🤷‍♂️
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Like others said, don't go crazy with spraying water and it's good. But the water drains through the holes at a decent rate and comes out right underneath onto the ground.
Not having carpet to clean is the best part. If you live in a snowy area, washing out snow melt, along with the salt and dirt, will be a breeze.
Also don't forget, under the washout flooring there is still the passive drain plugs that the carpeted broncos get. So if you get any water under the floor it still has a chance to drain out and get a bit of air.
My biggest complaint would be that the drain hole covers are part of the floor. Once you break the little cover connecting piece it's disconnected forever. There is no way to buy a replacement that reattaches.
MayhemMike
Mercury
Right here! Rubber floors. Nothing more to add.
