Fender Flare Staining...
Cousin Eddie
Jack
Pennsylvania
Cadillac
Is anyone else having issue with cleaning the fender flairs? I have a Badlands, squatched. No mods. Rocks and dirt get kicked up, and yes, I have paint chipping and marks on the fender flairs and door handles but I can't get the fender flairs clean. I use a car wash mit usually and the last time I washed it, I used a soft tire brush on them. Still no luck.
Any suggestions to get them clean without damaging the flairs?
Advertisement
AMK610
Andy
PA
2019 RAM 1500 Rebel
I know Adam’s tire cleaner can be used on plastic trims.
Where are you getting paint chips? Is it down to the metal?
FATHORSE
Stephen
okc
nissan
i wouldnt use any of those. lol.
Boxer4
TRUCK
Same issue. Stained from an ash colored mud about two months ago. Did fade over time.
Rick Astley
Rick
Seattle, WA
2-stroke unicycle
It's worth noting that every one of these products is a surface dressing and won't solve the problem in any way.
So grab the best one from the video and be impressed for the first hour!
This is what I would suggest for actually penetrating the plastic and restoring the black color.
This 1 oz bottle should be enough to do the flairs about a bajillion times over. A few drops of this stuff goes an insane distance. $12 well spent.
https://www.amazon.com/Solution-Fin...yl+Plastic&qid=1632180425&s=automotive&sr=1-6
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
Dang they do look pretty bad. I'm surprised as you can't have had it for that long. Is that how Wranglers are too? Good luck. Well to all of us.
Rick Astley
Rick
Seattle, WA
2-stroke unicycle
It's pretty standard for that type of plastic to lose color quickly. A neighbor had his Wrangler parked outside for about 10 years. I did a single coat of Solution Finish just to drum up a detail job for fun one weekend and it was night and day difference. Lasted about 18 months before needing re-application. I'll still call that money/time well spent as it only takes seconds to apply.
Before:
After:
Side by side:
The above is taken from AutoGeek's site. They are an excellent high-quality auto detailing retailer and i've had great service from them.
https://www.autogeek.net/solution-f...MIy5GaoduO8wIVUT2tBh2SnwzsEAQYBCABEgL0OvD_BwE
Full disclosure: I have no affiliation with AutoGeek or Solution Finish in any way. I get absolutely nothing, not even a Christmas card from them for suggesting their products. They have simply treated me fantastic over the past 25 years of car detailing both as a business and as a consumer so I suggest them to others.
Bronco67
Atlanta, GA
2 DR
Before:
After:
Side by side:
Have been looking for a more permanent solution for a while. Nothing was wrong with my material at first, I used a typical product as a preventative and it was what faded my fenders, and only lasted until it rained. Nothing has worked long term, I’ll definitely be buying a bottle to try it out.
Rick Astley
Rick
Seattle, WA
2-stroke unicycle
It's $12 well spent for sure. Obviously some plastics take it better than others (that's what she said!), but if Bronco fenders are anywhere in the ballpark of what Jeep's been using, it will do you a treat.
Advertisement
Lethal Performance
Advertisement
