First Bronco Mod questions
ojunior
Orrett
Chicago, IL
2014 Jeep Grand Cherokee
I am taking delivery of my Bronco early next month (BL/SQ/V6). I want to do some minor modifications to the exterior. Mainly I am interested in offsetting the tires a bit (more aggressive stance), ADD bumper (if it will not mess with my adaptive cruise control) and a winch.
I was wondering if I can just get wider beadlock tires and call it a day instead of doing the offset, and if there is any type of bumper that will not mess with my adaptive cruise control?
If i need to buy parts, what are some suggestions. Sorry, this is my first time modding a vehicle so I am a novice here.
Raptor911
Raptor911
Broadlands, VA
I assume you just want poke so just but wheel spacers OR you just can buy aftermarket wheels with more offset .. for example .. OEM SAS wheels are +30 offset so aftermarket wheel at 0 offset would push your wheels out 30mm.
I will let others answer the bumper question
ojunior
ojunior
Orrett
Chicago, IL
Thanks so much for the reply. So basically the stock SQ tires on my build have a larger diameter than these, so i should be able to get away with an offset and i'll be fine?
Raptor911
Raptor911
Broadlands, VA
Your OEM SAS wheels (17x8.5 at +30mm offset) will accommodate tires in this size with no issues >> 35X12.5R17LT.
OEM SAS tires are 34.4 in diameter and the tires you want to run is 34.5 ... .1 is not a big difference
Plenty of guys are running 35X12.5R17LT with no issues
