They been flaunting the FEs a lot lately, now showing the FE specific LB.
Wonder if they’re getting FE cancellations?
The Safari Bar is a stand alone option.Doesn't have the safari bar either. Maybe not quite done with it yet? ?
Arent these things supposed to be soft sprung in the back? That 150lbs could make a difference. Would like to see it with the top on to compare.Top shouldn't weigh more than 150ish. 2 doors being short are sensitive to the raked appearance. Now you know why jeep does use different springs with different tops and with/ without tow pkg. I'll be lowering the rear not liftingthe front, that's not the right move with this truck.
Cause they're working on a white modular for it? This is the only acceptable answer.How come they didn’t put the MIC top on it?
Standard for First Edition.The Safari Bar is a stand alone option.
This is why:totally agree, this is so much nicer than velocity blue. I don't know why they even have velocity blue
Is this true??Speaking of that someone needs to find out for sure if you are getting a taller spring with the tow pkg. So I can order it without it! So it sits level.
Always!?!! I took a nap and hot dang loving what I woke up too!! All this LB looking good!!@618TRVLWILD - Always lead with the Booty shot.
