5 minutes in a cad program and a laser cutter would have made easy work out that bracket. I hate to think of how much time and energy you spent drilling and cutting those bolt holes. Also, for version 2.0 I would suggest cutting out the center of the plate for the receiver hitch to nest in, this way you can weld the receiver to the front and back of the plate. With a full weld front and back I wouldn't hesitate to use that hitch set-up with the proper recovery gear (assuming that plate is at least 3/8" thick)
