Awesome. Will there be a complete kit with both the light and Amber module, or will I need to purchase each individually?
Hey is there going to be bundle or a Led option to buy both? Were we don't get 2 middle pieces.Here you go they are availble now:
https://www.oraclelights.com/produc...-led-module-for-ford-bronco-flush-tail-lights
At this time we are just offering this as a separate option to be added to our tail lights.Awesome. Will there be a complete kit with both the light and Amber module, or will I need to purchase each individually?
PDF install guide here
by chance do you know if the DRL circuit is controlled by LIN BUS as well? Wanted to tie the DRL side of my RC light bar into the DRL circuit, but when testing did not get any power out of that pin. Not sure how bright it will be at night so don’t know if I want it on with the parking lights.
Will this module still require ForScan programming?
No, if you have LED it will require no programming (you already have amber turn signal with LED) if you have halogen then yes you need to switch it to LED in Forscan.
Hey Everyone - Just want to drop a few clarifications hereI had base lights before I put yours in. Am I understanding correctly, Ill need forscan to switch to the amber signals?
I have already placed an order for the new ad on .
I have the base model with halogen lights and was previously informed that these would work. Can you come up with some type of solution?
The entire reason I purchased the flush mount tail lights was for the amber turn signals.
Please help.
I am traveling at the moment but will be back in the office in a couple days & will share this here.I am open to trying that method. Please send a diagram. Thank you.
When will these ship?
With extra effort you could add pins/wires to the BCM for the dedicated amber left/right turn signals, and the run wires to the rear tail lights. Did the same process upgrading an F350 to OEM LED headlight modules. It is delicate work disassembling the connector top and adding pins.I am open to trying that method. Please send a diagram. Thank you.
When should these ship?I am traveling at the moment but will be back in the office in a couple days & will share this here.
Thanks for your patience.
I like that plan even better. Is there something you could send that might help a novice?With extra effort you could add pins/wires to the BCM for the dedicated amber left/right turn signals, and the run wires to the rear tail lights. Did the same process upgrading an F350 to OEM LED headlight modules. It is delicate work disassembling the connector top and adding pins.
These are shipping this week.When should these ship?
