I missed the part where the brake light would also be amber. I'm okay with having both red and amber for the signal but not okay with amber for the brake lights.The only workaround that I could see being viable would be to tap the provided signal wire into the stop/turn wire on the lamp. This will give you the amber signal but the red signature light will still also flash. Also, the amber LED will illuminate when braking.
Happy to provide a diagram for this for those interested. Otherwise, feel free to PM me your order # and I will forward to our orders team to have it cancelled.
Again, this is simply a limitation on the vehicle side, as the truck is not wired for the separate signal, like the premium trims are.
What do you think about this?
With extra effort you could add pins/wires to the BCM for the dedicated amber left/right turn signals, and the run wires to the rear tail lights. Did the same process upgrading an F350 to OEM LED headlight modules. It is delicate work disassembling the connector top and adding pins.
Is that something you could assist with? I am pretty handy and willing to try most anything.
Please let me know; otherwise, I will have to cancel my order.
THANK YOU!
