I like both solutions. Do you happen to have a picture of this standing back further?
I’ll get another one today for you with the doors on.
Perfect! Thank you Sir.
CorrectIs this keypad wireless, and all you are doing is relocating the pad which is simply adhered from the factory using outdoor double sided tape?
I still dont know why Ford didnt put this in that spot within that trim piece. I wish someone in the aftermarket would make that trim to accept the guts of the num pad.this is where I installed mine.
First Mod was to move the keypad. Saw a video of keys that can get locked in back under security cover. Figured this would solve it. Second was to remove the door warning stickers and cover the VIN and tire labels to look cleaner with doors off.
I think the textured top will become a problem for adhesion in the long run.this is where I installed mine.
it could be I used some pro-bond to help with adhesion.I think the textured top will become a problem for adhesion in the long run.
This looks pretty good.!this is where I installed mine.
