So with a 7/30 reservation timestamp being a base 4 door SAS mic top I might have a chance at coming soon or closer to a 22myThe much anticipated scheduling has begun and we've learned a few things. Here's a few notes I wanted to pass along.
1 - First Edition doesn't mean First Production. Don't get me wrong, the First Edition will still be prioritized above other orders, but the first 7,000 units to roll off the assembly line aren't going to be first editions. We tried to explain that previously, but it is clear now that it is not the case. In my mind the biggest advantage of the First Edition now is that you are guaranteed Sasquatch and Lux package in a reasonable time frame.
2 - Timestamp is ONE factor in the allocation process. It is a very important factor, but it is not the only factor. Commodity restrictions are going to be evident moving forward. Trim, Doors, Options, are going to place a large role in what Ford can build. Keep in mind these restrictions will vary monthly. But the first week of production has given us a good view into what options may slow down your build. We have all 26 of our allocations scheduled already. Here is the break down for dates that reservations were placed.
07/13 - 12 Builds
07/14 - 6 Builds
07/15 - 1 Build
07/16 - 1 Build
07/18 - 1 build
07/20 - 1 build
August - 2 Builds
October - 1 Build
November - 1 Build
3 - How come my 7/13 build wasn't chosen???
1 - Sasquatch. The Reservation tracker on B6G sites 40% of reservation holders chose sasquatch. We receive 3 Sasquatches out of 26 builds.
2 - Lux Package - 47% of our reservation holders chose the Lux package. We receive 3 schedules out of our 26 orders.
3 - Soft Top - Out of the 19 orders for 4 doors we got scheduled 10 of them are soft top. Definitely a much larger representation of the orders than the general take rate.
So Ford is filling orders as they can get supplies. Say 10% of their production goes to Lux and they are out. That leaves us with 54% of our orders as eligible to be produced. Then they run out of sasquatch and badlands trims which leaves us with 30% of our orders to choose from. The process keeps on going until they can find something that they can build.
So what do we take away from this?
1. If you have a Big Bend, Black Diamond, Outer Banks, or Base trim and you aren't adding Lux or Sasquatch. Make sure your order isn't in "99" assuming you'll receive a 2022. There's not a great chance, but make sure you convert your order to a buildable unit. You may get pleasantly surprised.
2. Don't Change your order around because of this month. These commodities will change monthly. Don't switch your badlands, Lux package order to a base 2.3, 7 speed, soft top. Get what you want, but have realistic expecations on timing. If you are debating between a Black Diamond with and without Sasquatch, then you'll need to weigh whether waiting an extended time is worth it to you or if you would rather get it more quickly.
3. You are a FE reservation holder? Our first month we only received one of around 50 FEs. The take rate will speed up. I'm sure over the next 3-4 months the orders will get scheduled. Like I wrote earlier, The biggest advantage you have is you are guaranteed a LUX and Sasquatch, where a lot of others will need to wait. The pace of production of FEs will speed up significantly as well. So don't worry about that, lets see what month 2 brings.
Zach
I'm confused.
