First purchase for the new AMB 2 door: Ranger Raptor wheels
johnbasler
'23 BB 4d, '73 K5 Jimmy, '67 Mustang, '03 TJ Rubi
First purchase made for the Bronco. These Ranger Raptor wheels will be going on my 2 dr AMB Base manual with a set of 33s. Super pumped - my build is still scheduled for 7/5 so wanted the wheel/tire package ready for Bronco arrival.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
They look really nice.
What size are they and what is the offset?
Also, can you weigh one before you mount tires?
johnbasler
johnbasler
They are 17x8.5. +55 offset like the stock wheels. I can throw them on the scale - I think they said 30lbs. I like the factory wheels for strength and corrosion resistance, and I like the style of these over any of the stock options.
Broncola
Hawaii
Element, ā€˜75 Bronco widow
Iā€™d run these if I could find some cheap takeoffs, but kind of pricey otherwise w/ all the other choices out there. Nice though and good offset!šŸ‘šŸ½
johnbasler
johnbasler
I honestly think these are not a bad price - $840 for 4 from Summit with TPMS sensors and tool. I bought a set of 5 new Rubicon take offs with 285/70/17s for $800 - then sold the wheels for $500. So I am into the whole wheel and tire package for $1100, and I can reuse my stock Bronco tires on my Suburban. So I am not sure how much cheaper you can do something similar.
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
cool pick up. Interested in seeing what they look like installed. I did not upgrade the rims on my Badlands order. I plan to either rock the stock rims (I like the badlands alum rims) or maybe pick something up in a 8.5 wide. Nice to know there is something if I really need that extra .5...otherwise I really dig the method trail lock or whatever inner bead setup they call it, but would like to run +33/SAS offset if possible.
Rivers90
Ben
california
xterra mx5
You only got 4 rims? What will you do for the spare?
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Be careful running your Bronco tires on the Suburban. The Bronco tire weight rating is likely too low.
johnbasler
johnbasler
I have a 5th tire for a spare already. I have not decided if I will run a steelie with a cover for the old-school look, or just pick up a 5th matching wheel. I figured I can make that decision later.
johnbasler
johnbasler
it looks like the weight rating actually might be fine - it is just a half-ton 2wd Burb, but will verify before doing so.
johnbasler
johnbasler
The Ford dealer was kind enough to mount these up for me. Hopefully the Bronco arrives soon :). (Scheduled for 7/5 build as of now)
Erock
US
2018 F150 Alpine edition
Congrats on the wheels... and the build date.
Broncola
Hawaii
Looking forward to seeing these on your bronco. Are you mounting them day one?
Ford Bronco First purchase for the new AMB 2 door: Ranger Raptor wheels B8527DB4-A44A-4D7D-B61E-03E77B447604
johnbasler
johnbasler
Yes - looking forward to getting them on day one. Unfortunately my Bronco that was built on 7/14 is still sitting on a lot at MAP. Good times...
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
I like these wheels and definitely look forward to seeing these on your truck. If I change my order to base I would look at doing them as well, but Iā€™d probably stick with 265/70R17 tires because of the 2.3L manual.
As for load rating on the stock tires, the stock tires on my Tacoma (112) exceed the stock tires on my 2000 Expedition (108) , so itā€™s very possible the Bronco stock tires will have sufficient rating for the Suburban.
