- Aug 9, 2020
- 0
- 100
- 318
- Massachusetts
- Ford Escape
- Badlands
Nice! Post more photos of that Velocity Blue Badlands!
UnicornA Non-SAS Badlands with a hard top, nice!
You need a new wife. Your current one is defective.I'm just jealous you have a matching Bronco and RZR (wife won't me get a RZR )
The heavy-duty payload package on the F-150 dumps the heat very effectively, but has significantly more cooling capacity. It makes a huge difference in towing heavy.I’m curious what your water temp was. I’m guessing the 2.7EB in that package isn’t taxed much. The EB’s will pull like no other but low RPM’s and lots of load (boost) will build heat in the turbos.
My 2nd gen 3.5EB would have the power to accelerate up an 8% grade pulling a 9000lb travel trailer, the problem is it couldn’t get rid of the heat fast enough. I never had it go into power reduction mode (252 water temp I believe) but I did see it hit 245 a couple times and would regularly pull grades (when towing) at 235-240.
People like to say it’s an intercooler issue but ambient vs. intake temps never varied much than a delta of 10 degrees.
With the 6-speeds, yes. All the 10-speeds, 3.5EB’s come with the larger radiator factory so all you get with the heavy payload are the tow mirrors, lower rear end gears, big fuel tank and the trailer items (back-up pro and brake controller). The 6-speeds came with a bigger radiator and an remote transmission cooler. My old F150 was optioned with all that stuff, save the tow mirrors and the door sticker for the payload.The heavy-duty payload package on the F-150 dumps the heat very effectively, but has significantly more cooling capacity. It makes a huge difference in towing heavy.
Sounds spot on, ya, I have the 6 speed, but keeping the RPM between 3200 and 4200 is still the ticket to keeping everything in the green as far as best performance and mileage.With the 6-speeds, yes. All the 10-speeds, 3.5EB’s come with the larger radiator factory so all you get with the heavy payload are the tow mirrors, lower rear end gears, big fuel tank and the trailer items (back-up pro and brake controller). The 6-speeds came with a bigger radiator and an remote transmission cooler. My old F150 was optioned with all that stuff, save the tow mirrors and the door sticker for the payload.
The largest issue with the 10-speed is that is WANTS to run the highest gear possible, even in tow haul. Top 3 gears are OD gears. I found I rarely had an issue with “runaway” temps if I locked out 8-9-10 and just ran in 7th. If I missed the momentum coming into a hill, I may had to run down in 5th. The key was to keep the RPM’s between about 3200 and 4200. That gave enough power on the steep grades, kept the motor in the right torque/hp range and kept the water pump moving.
Interesting. Is that at a moderately high elevation? I have a Sierra 5.3L, and though I assume it to be a fair bit lighter than the Suburban, it tows my RZR 4S like a boss....had some pretty good climbs to get to our riding spot. In the past, the steepest and longest climb had the Suburban in 2nd gear doing 40 to 45 mph.
It was actually my wife's idea to get our RZR. I like it, but she really likes it.You need a new wife. Your current one is defective.
Haha. Different animal. I hear people complaining about little paint chips on their roll bar. I cant imagine how happy they would be doing this in their Bronco. In the RZR, its no big deal.Why do you need that thing on the trailer? You have a Bronco!
I have to start out by saying that someone who owns diesel trucks will have a different perspective than I have. To them, the Bronco 2.7 will probably be way under-powered. However, my background in towing has mainly been with the Dodge Durango with the 5.2 and the Chevy Suburban with the 5.3 (with 3.42 gears) . I have towed snowmobiles, ATVs, SxS and camper trailers. They have towed alright but once we start climbing, they struggle.
Enter the 2.7 Bronco! Like I told my wife, this is a whole new world! We took the RZR (weighs about 2,800 lbs.) out on Monday and had some pretty good climbs to get to our riding spot. In the past, the steepest and longest climb had the Suburban in 2nd gear doing 40 to 45 mph. I was expecting the Bronco to do better but it really surprised me. On the same hill, the Bronco was cruising at 55 mph at about 1/2 throttle. RPMs were about 2,800. Engine didn't feel like it was being pushed at all. Stepped on the throttle a bit and started to accelerate! I had perma-grin. This power combo has exceeded my expectations. This little engine may not be very quick off the line but it has lots of torque. I am loving the 2.7!!! I just hope it proves to be durable and reliable.
BTW, Sledboy, i really appreciate the real world towing report, and I'm glad I ordered that 2.7, which I also have in my F150. Looking more closely at your photo, you have an excellent car-trailer combo and the squat isnt too bad, and your adjustable height hitch lets you level the trailer very nicely. And a dual axle trailer would be overkill and take away from payload with a 3500# max anyway. Looks like great fun, hopefully mine will be released from Purgatory soon! Blessings!I have to start out by saying that someone who owns diesel trucks will have a different perspective than I have. To them, the Bronco 2.7 will probably be way under-powered. However, my background in towing has mainly been with the Dodge Durango with the 5.2 and the Chevy Suburban with the 5.3 (with 3.42 gears) . I have towed snowmobiles, ATVs, SxS and camper trailers. They have towed alright but once we start climbing, they struggle.
