Yes, it does. It has a different suspension. “Unique Badlands Suspension“ in the comparison sheet. It is lifted more than standard with the HOSS suspension.Badlands doesn’t mention anything different about it’s suspension vs. Big Bend. Seems like an easy swap. ?
That I would highly, highly doubt. Very little chance you’re fitting 34s on a standard trim (Without Sasquatch) other than Badlands.Pretty sure you could get 34s on any trim without any mods. They all have the same suspension, axles lengths, and fenders. only the ?badlands? And sasq have the Hoss suspension which has the lift and 35s. I have not seen confirmation of 35s and regular suspension working together. But it might be possible with a loss on suspension travel.
The different suspension could be just the electronic sway bar disconnect...Yes, it does. It has a different suspension. “Unique Badlands Suspension“ in the comparison sheet. It is lifted more than standard with the HOSS suspension.
It’s not. Different shocks and springs and lift.The different suspension could be just the electronic sway bar disconnect...
idk
Under day to day pavement cruising it might be ok. Assuming that you don't go full rebound on the shocks. Way down low you most likely won't be touching the sheet metal at all. But Would you want to risk that occasional, again around town, major impact to cause the wheel to go up into the wheel well/fender? I would guess 33 no worries on any trim but 35s yeah.That I would highly, highly doubt. Very little chance you’re fitting 34s on a standard trim (Without Sasquatch) other than Badlands.
This is my goal as well. I may even ask the dealer to swap the 32s for 33s before I pick it up (assuming they will fit without issues)Wondering myself if 33's will fit a BD without modding anything
I stand corrected. You’re right. It has the HOSS Bilstein shocks. So, that’s the little bit of lift they gave it for 33s.Yes, it does. It has a different suspension. “Unique Badlands Suspension“ in the comparison sheet. It is lifted more than standard with the HOSS suspension.
