FLASH SALE | 20% OFF | UDA Air Compressor Engine Mounted Kit
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
It's time for ANOTHER one of our famous FLASH SALES. This time we're taking 20% off our UDA Air Compressor Kit for the 2021+ Broncos. This kit includes our patent pending KR Off-Road Compressor Mounting Brackets, which bolt quickly and easily under the hood of your Bronco. It also includes a UDA Air Compressor & ARB Pump Up Kit.
This entire kit is 20% off the normal price! This sale is for a LIMITED TIME ONLY (while supplies last) so if you want to take advantage of this you need to ACT FAST.
No coupon codes necessary just add the kit to your cart, the discount is ALREADY built in!
https://www.4x4truckleds.com/kr-off...021-ford-bronco-w-uda-compressor-pump-up-kit/
Ford Bronco FLASH SALE | 20% OFF | UDA Air Compressor Engine Mounted Kit Flash Sale - UDA Kit
If you've been looking for an easy to install mount for your ARB Single, ARB Twin Compressor or UDA EGOI 2 Compressor, look no further. KR Off-Road was the first in the industry to offer a commercially available Compressor mount for the new 2021+ Ford Broncos. This system is 100% bolt-on and uses factory mounting points. With support for both 2.3L and 2.7L engines you'll be able to mount the ARB Single Compressor, ARB Twin Compressor or UDA EGOI 2 Compressor under the hood of your vehicle. The installation only requires a few hand tools and can be done quickly and easily.
FEATURES
  • .135" (10 Gauge) #304 Stainless Steel
  • Powder Coated Black Finish
  • Designed & Manufactured in the USA
  • Bolt-On Installation (Utilizes 4 factory mounting bolts)
  • Patent Pending Design
INCLUDES
  • 1 Compressor Bracket
  • 1 Support Bracket
  • Up Down Air EGOI 2 Compressor
  • ARB Pump up Kit
FITMENT
  • 2021+ Ford Bronco w/2.3L Engine
  • 2021+ Ford Bronco w/2.7L Engine
  • Will not fit trucks equipped with a snorkel or the Bronco Raptor.
  • Compatible with most aftermarket air intake systems (not all tested, but so far no reported fitment issues with any)
Ford Bronco FLASH SALE | 20% OFF | UDA Air Compressor Engine Mounted Kit Photo10
Ford Bronco FLASH SALE | 20% OFF | UDA Air Compressor Engine Mounted Kit Photo13
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We still have a FEW UDA compressor kits left at this price!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
