Flat tow equipment needed to flat tow the 2021 Bronco?
JimboSlice
South Lake Tahoe, CA
2022 Ford Bronco Outer Banks 2018 Audi Q7
I’m pretty happy with how my flat tow setup turned out.
I ordered by Bronco with the modular bumper, but was required to switch to the capable bumper to get my allocation. So I made a quick swap to the ford performance tow hooks.
I’m using a blue ox alpha 2 tow bar, and universal d ring adapters for the blue ox bar. RVI brake 3 system with an Ankler 521 power station seatbelted in the front seat to provide uninterrupted 12v power to the brake system.
Gen Y hitches makes a nice 10K rated adapter to raise up my hitch for flat towing the Bronco now and can still be used if we lift it more. It also fits a double bike rack between the Rv and Bronco while still allowing tight turning. I had to order longer safety chains and coiled power cord to make this work well. We also mount another couple bikes behind the Bronco on a swing out carrier.
We are getting excited to head to the Keys for Christmas and New Years with the new setup.
I am going to go with tis set up, thanks for posting. Can you tell me which bike rack that is?
6inthefamily
IL
Tacoma, Bronco
I use a Yakima hold up 2 bike carrrier. One behind the RV and one behind the Bronco.
lamokadave
Nice and tidy
and yes Bsenecal I have the Lode brackets so I can use the recovery hooks.
Id like to duplicate how and where you mounted your 6 pin plug. How did you get it to mount into the inner elliptical hole so that it sits flush. I tried to fit my Curt 6 pin in that area and it's way too large without cutting out that inner ellipse. We just ordered a Hopkins in case it's significantly smaller. Did you need to mod that opening?
AUG41
Marcelino
MI
2024 Bronco
Friend has a machine shop- so when we took off bumper we took off inner bracket of the bumper then he cut around it and repainted it before we reassembled the bumper. You can mark the inner bracket with a pencil so you know how much material needs to removed. The tricky part is removing material on the plug to fit under the cover and clear the tabs. We then used stainless machine self tapping screws to attach the plug. After we drilled a pilot-it will to go through the bumper and almost or into the bracket depending on length of screws
WVBroncoMark
WV
2023 Ford Bronco Wildtrak Sasquatch
Hi everyone! I'm new to the forum and getting set up to flat tow my Bronco. Appreciate all the great posts and info here in this thread! I just have a question about the LOD brackets. From previous posts, it seems some use them and some do not. When I upgraded my D-rings on the Capable bumper to the Ford Performance Tow Hooks, the frame horns seemed fairly beefy, so I did not add the LOD brackets. Question: are the LOD brackets a must? Or are they added more for convenience for a place to attach safety cables?
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? IMG_7029.JPEG
Fordified1
Bob
Mid South Texas
Because some bumpers have been completely ripped off the frame during recovery, made some of us think the LOD brackets might be a good idea for flat towing.
lamokadave
Hi everyone! I'm new to the forum and getting set up to flat tow my Bronco. Appreciate all the great posts and info here in this thread! I just have a question about the LOD brackets. From previous posts, it seems some use them and some do not. When I upgraded my D-rings on the Capable bumper to the Ford Performance Tow Hooks, the frame horns seemed fairly beefy, so I did not add the LOD brackets. Question: are the LOD brackets a must? Or are they added more for convenience for a place to attach safety cables? In the bumper attachments
If you search YouTube for LOD tie in brackets install, you'll find a video of a guy who was rescued in Moab by Matt's Recovery. He speaks about the weakness of the front recovery points on the Bronco. I also asked a mechanic at my local dealer. He had first hand experience with weakness of the bumper attachment as well.
I have a BL SAS with modular bumper. The LOD brackets interfered with both the bumper and front bash plate so I just cut the hook section of the outer brackets off.
There are frame stubs where non SAS models have crash bars. Those offer opportunity to be used as attachment points for safety cables.
2ndgenirish
William
Ford Edge Sport
Does anyone know if the factory modular bumper on a 2023 Raptor is the same factory setup as a Badlands? That is, do Raptors need the LOD brackets?
Fordified1
Bob
Mid South Texas
The YouTube bumper attachment failure mentioned above was a Raptor I believe. Pretty sure all the framehorns and hardware are identical.
Dirtrider
Bruce
St. Louis
Honda Ridgeline
If you have the ability to bend the LOD brackets, (press brake required) you can bend the 'hook section' outward 60 degrees parallel to the bottom edge 2" up from the bottom edge and it will clear the modular bumper, not sure about the capable bumper. I then used a 1/2" quick link: Curt Threaded Quick Link - 1/2" Diameter - 3,300 lbs CURT Accessories and Parts C82932 (etrailer.com) that extended down far enough between the bumper and the front of the bash plate to connect the safety cables to. I had to do a little creative hammering on the front edge of the bash plate (~1/8") for the ring 'nut' to clear, (I have the crash bars and wanted to retain them).
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 1715904472785-di
Ford Bronco Flat tow equipment needed to flat tow the 2021 Bronco? 1715904864966-qz
Sethtsmith
Seth
2012 F-150 FX2 Supercab
I personally installed the LOD brackets on my 22 wildtrack with modular bumper and did not have to cut or bend anything. I removed the bash plate first as it is a tight fit and not much room to work with, but installed without issue, besides a bit of cussing here and there. After install , put the bash plate back on easily. I also found installing quick links like the post above was helpful with connecting and disconnecting the safety chains.
Dirtrider
Bruce
St. Louis
Honda Ridgeline
Interesting. There was no way that I could reinstall the bumper with the LOD loops where they were. I have the Ford Brush guard and the LOD loops hit the bottom back bracket on the bumper (the bracket that the silver bolt heads are holding on in the picture above) which caused the bumper to tilt back and the brush guard was hitting the grill. My Black Diamond is a 2022 if that makes any difference. I sent my drawings and issues to LOD, maybe they changed the brackets:wink:
Sethtsmith
Seth
Perhaps that is the difference. I do not have the brush guard, so no brackets to interfere with the install. Or as you say, they may have tweaked the design and I had the new version.
