- Thread starter
- #1
I finally have a build date for my Bronco. It is to replace my current toad. (Ford Edge)
In preparation, I am working through what I need to setup the rig to flat tow as soon as possible.
I have read the "flat towing equipment needed" thread several times and it was very helpful.
I search for a supplemental braking thread and got very little info.
My plan is to use the Roadmaster Falcon tow bar I am currently using and change the ends to the 035-1 adapters. Funny that Roadmaster nor etrailer suggests this setup. I saw that Ford would not provide BlueOx with the specs so they (blueox) designed their own bracket. I guess the others followed. Very silly but no shocked by today's lawsuit happy world.
I have a spare diode kit from my previous toad (Ford F150). This solves my lights.
This gets me to my question.
I currently use a Roadmaster Evenbrake for my supplemental braking. I have used it in my last two toads. It does a great job and I know how to install it. My only complaint is that when its not in use, its always in the way and I have to drag the thing in an out of position.
I want to setup the Bronco to flat tow quickly. ie built in
I have seen the ready brake solution suggested. I am considering it but want to make sure I have looked at all the options.
I don't have air brakes.
My options are?
Demco Stay-n-play?
RM Invisibrake?
Are there others?
What is easy to install?
Easy to put into action?
Won't drive me nuts with false braking and all the other annoying things supplemental braking systems can do?
My options are?
Demco Stay-n-play?
RM Invisibrake?
Are there others?
