Floor Liners on washout flooring?
Go_PRE
PRE
NH
Yukon Denali/BMW 750
I ordered a BL with MGV, so I will have the rubber washout flooring. I also ordered the rubber floor liners. Was that a waste of money or is the additional redundant protection worth it? Are most people with washout flooring ordering the floor liners?
PWillette
Parrie
Maine
'89 Land Rover 90 p/u, '01 SS Camaro, '21 Bronco
I believe BL comes stock w/ carpeted floor liners for front seats and second row so I didn't opt for the rubber floor liners although I do like the looks. Either way it will add a layer of protection...the rubber floor will eventually deteriate in heavy wear areas. I'll use the stock carpet matts then eventually go with weather techs.
FourHorses
Currently own 6 Fords
I still plan to put in WeatherTech floor liners even with the washout floors. I've had Fords rubber liners and WeatherTechs. Although Fords are more pliable and less slip resistant, I prefer WeatherTechs due to the perfect fit, and ease of pulling them out with the water/snow/mud contained within them for simple cleaning.
dominicenoa
Dominic
Oregon
2021 Ford Bronco Badlands
I got the liners. I know eventually the rubber flooring would start to wear away just from constant use (especially around the pedals). The liners will protect from that and I can still pull them out, hose them off and wash out the interior.
Julz670
Julian
Minnesota
www.youtube.com
Previously: '83 and '95 Bronco XLTs. RIP.
I thought about it but decided not to. I'm not sure what the added benefit would be of having a rubber floor liner with washout interior, other than long term wear and tear. I'll keep the carpet floor mats in for daily driving just so it looks nicer and reduces wear, but will go with just the bare washout floors when off-roading or camping.
Rickperry
Phil
Houston
www.bdusa.co
2021 SAS Badlands / 2022 BaseSAS
I bought it to "protect" the rubberized floor. Can't speak on the durability of the washout floor, but I can forsee years of pedal use will eventually wear it thin. It's I've had this happen on all types of rubber floormats, that TPU floor won't be any different. Plus it adds more grip to the floor.
Can't beat the convenience of throwing out the mat and power washing it. You wouldnt use a power washer in your car regardless of it being washout lol
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I’m still going to put some sort of mat on top of that washout floor for protection. Easier to replace the mat eventually if I wear a hole in it with my heel than the actual vehicle flooring
I believe it’s 4-door only for the carpeted floor mats. At least that’s what the order guide says. Not sure what to expect on the 2-door. (I would have expected at least front of row mats)
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
I got the mats as well. Make the floor more finished looking, and will help with a little sound deadening.
PWillette
Parrie
Maine
That could very well be as I did not look at the 2dr...would be strange if the 2dr didn't get the matts but who knows!
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I got the liners with the MGV as well.
No interest in using the carpeted mats with the rubberized flooring, as that would just mitigate the ease of cleaning.
Hadn't really given much thought to what I wanted to use instead, but when I saw the pics of the liners I immediately liked them. Nice look and a few more Bronco emblems for the ride.
I figure most of time just pulling the liners out to rinse off will be sufficient. And when it's not, I've got the rubberized floor with drains.
MadMan4BamaNATL
Ray
Atlanta
I plan to take a wait and see approach to liners with my wash out floor. Want to see just how rugged the floor will be and don't care about it being dirty often.
However, I do recognize that while wheeling I'll be wearing boots with aggressive lugs that can wear out anything. If I start to see some wear, will do as others and pick up some WeatherTech liners.
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
I did the same for my Black Diamond. The Bronco floor liners look similar to WeatherTech liners and I love them. Pull them out and hose them off. I also wanted the rubber flooring...in other words something other than carpet. I like a clean vehicle and both will assure that.
MacHudson
Northern New Jersey
2012 Edge
It’s probably a good idea. I wore a hole clear through under my heel in the driver seat on my Ford floor liner in an Edge.
so let the extra mats take the abuse instead of the rubber floor
bonus - the first 10 pounds of grit and crap can be vacuumed out and lifted out to spray free from the removable mat. No need to get the inside soaked every time you want to clean it
