FM radio goes fuzzy when rigid lights are turned on.
Thomas1984
Thomas
St.johns Newfoundland Canada
Dodge Viper
Anyone have any solutions on why the FM radio goes fuzzy when I turn on the rigid mirror lights, I installed this stubby antenna from craven speed it looks sweet but the radio goes fuzzy when I turn on the mirror lights. I don’t have this problem with the factory antenna. Any solutions welcome!
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
General electrical interference. Try different lights, try a different antenna, swap back to the OEM antenna, try adding some distance between the light and the antenna… might even be a ground loop.
If all else fails, don’t use FM
Bronco21fan
Angelo
NewJersey
Ford Bronco FM radio goes fuzzy when rigid lights are turned on. C93C33B2-1E2A-475C-B8C1-988DF004475D
It could be the stuby antenna I had one for my 07 mustang gt and it was shit
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Put stock antenna on. That baby one is the problem
SamG
Sam
Detroit Area
sas
I have the OEM antenna and rough country mirror lights. Same issue. the wiring runs too close to the antenna is my belief. General electrical interference.
My radio is actually slightly fuzzy even with it off and gets WAY worse when its on. Dope!
Bschurr
NY
Try installing a ferrite on the power cable - this should eliminate the EMI (Electromagnetic Interference)
Thomas1984
Thomas1984
Thomas
Dodge Viper
It doesn’t happen on mine at all with the OEM antenna. Only with the stubby
Bschurr
NY
Broncojy
Johnny
Dodge Neon
U have a link for these lights?
