BroAD
Adam
Illinois
2012 Ford F-150
Update 1:59PM Pacific - It appears the Q&A has now concluded.
As a group, Bronco6g asked @Ford about 100 questions and responded to about five. The other questions below were asked by other users, some of which may be Bronco6g forum members.
* since all the questions & answers are below, I will not be exported the Twitter thread as originally thought
Below are the Q&A answers from today's session with Ford.
* answers list excludes generic 'stay tuned' or unhelpful questions/answers
Q: Will there be a sliding tray available for the 2 door model to level the loading area with the seats like in the 4 door?
A: No, this will only be for the 4-door.
Q: What axle gear ratios will be available?
A: Bronco 2-door and 4-door are available with: 3.73, 4.27, 4.46, 4.7.
Q: Will the Base model Bronco be available with a tow package?
A: It's not available on the Base Bronco, but can be purchased as an aftermarket accessory.
Q: Will the 2-Door Base w/ Sasquatch mode be available with a manual transmission?
A: Sasquatch package is only available with auto right now, let us know what you think about a manual combo.
Q: Will the electronic sway bar disconnect be available as a stand-alone option on the Wildtrak and/or Black Diamond trim?
A: The sway bar disconnect is only available on Badlands and First Edition.
Q: How much will the Sasquatch package cost? Also, cost of the v6 and 10 speed transmission?
A: We'll be sharing pricing this fall before ordering begins this December.
Q: Can items from the Sasquatch Package be opted out of, like the oversized fenders?
A: Sasquatch has big feet and needs big fenders. They are not optional.
Q: Does the Sasquatch package come with wheels with silver/gray paint OR chrome? I do not like all black wheels.
A: There are two different ring colors available on the wheels depending on the series you select. There will also be additional ring color options from
@FordPerformance
Q: Will all Broncos that opt for the 2.7L upgrade receive the 'Sport' GOAT mode similar to the Wildtrak?
A: No, G.O.A.T. modes are determined based on the series of your Bronco not the engine you select.
Q: Is the max towing on the 4 door Bronco 3500 lbs or is it still being tested with the tow package?
A: Max available towing is 3500 lbs.
Q: Are the upfitter auxiliary switches pre-wired to both the front and back of the vehicle?
A: Yes, the switches are wired to a fuse box under the hood.
Q:
1. On the black Diamond I would like to get the Sasquatch package. Can I get the 2.3 engine instead of the 2.7 (do want automatic)
2. How much room between back of seat to steering wheel if seat all the way back?
A:
1) Yes, you can get a Black Diamond with Sasquatch, a 2.3L engine, and a 10 speed auto. 2) We are looking for our tape measures.
Q:
1. Sasquatch package limit articulation and travel compared to Badlands package?
2. 2.3L factory tune offered with manual transmission?
3. Manual transmission with 35" tires be available for model year 2021?
4. Manual transmission with 2.7L be available for model year 2021?
A:
1. Correct, with 35" tires articulation is slightly limited vs. 33" tires.
2. We will have more to announce on accessories soon.
3. We hear you and are listening.
4. No.
Q: My wife is a smaller person. How heavy are the doors and can a single person take them off?
A: We designed them to be as easy to lift and remove as possible. The heaviest door on the 4-door Bronco will be a little over 50 pounds and can be stored in the cargo space.
Q: Will a Sasquatch Outer Banks still have painted fender flares?
A: No, they are not painted.
Q: Rumor has it Ford is going to offer a 2” lift running on 37” tires . True or false ?
A: Sorry we can't comment on future products.
Q: What is the weight capacity of the supplied roof rack as it looks to attach in the front and rear with no mid support?
A: 110 lbs. while in motion and 450 lbs. parked.
Q: What are you expecting for MPGs?
A: We'll release this information in the future. Stay tuned.
Q:
1. Sasquatch with a manual don’t care which engine makes it happen?
2. 5.29 ring and pinion option?
3. Possible lower gear set for the T-case?
4. Rubber floor,vinal interior,sway bar disco,lockers “al a cart”?
A:
1. We hear you and are listening
2. & 3. These will not be available from the factory
4. Rear lockers are available on most series as a free standing option and front & rear combo lockers are available on all series with Sasquatch.
Q: Will there be a roof rack system that allows total roof removal?
A: Our roof rack is designed to allow the 2 front row panels to be removed on the 4-door Bronco, and the 2 front row roof panels on the 2-door Bronco to be removed with the roof rack in place.
Q: Are people going to be able to see the 2 and 4 door in person as well as color options before placing their order in December? Lots of anxiety about this topic in the forums.
A: The Bronco 2- and 4-door build and price will go live before ordering begins in December. There will be some events where people can see the Broncos in person but events are limited due to the pandemic.
Q: Since the bronco has an auto on/off stop feature does it have a brake hold feature?
A: Hill start assist is standard on all Bronco 2-door and 4-door.
Q: Are the cabin drain plugs in all trims or just the “rubberized flooring/washout interior” and are the in both front/rear rows?
A: Active drain plugs are only available with the rubberized flooring. There are passive drain plugs in all 2- and 4-door Broncos.
Q: What is included in the tow package? Do broncos without a tow package still include a hitch?
A: Trailer tow package comes with an optional 2" receiver hitch and trailer wiring connector.
Original Question Posted:
Will the Ford Bronco and Ford Bronco Sport be offered with AXZ plans?
When can we see a Ford Bronco dressed Area 51?
Is the rear swing door removable?
Will there be power seat options on 2-door Badlands?
Are there any pre-production vehicles being tested using the 7-speed manual transmission?
What is the load capacity of the roof rack?
What impact does the Sasquatch package have on badlands suspension travel?
What is the earliest an early reservation holder could order and then receive a Velocity Blue Bronco?
Any way to order a two door with a three person rear seat?
Is Navy Pier the only interior option on the Full Sized First Edition Broncos?
Will the side windows pop out without the hard top being removed?
Any pricing available for packages before configuration tool comes out in August?
Can the roof rack be secured without the top installed?
What parts of the Bronco frame and suspension are unique from the Ranger?
In what order will the reservations be fulfilled?
What is the difference between "Ford Co-Pilot360 Technology and "Ford Co-Pilot360"? (As they are different line-items in the spec sheet, and the latter isn't available on the First Edition.)
Are full-belly skid plates going to be an option accessory?
Will the front passenger seat fold flat like the Ford Flex?
What is your time frame for getting accurate metrics on your preliminary spec sheet?
Can you explain the difference between modular and non-modular hardtops.
What are the leather color options?
Where is the B&O subwoofer located in the Bronco? Does it skew dimensions of cargo area if that’s where it’s located?
Can you clarify leg room between 2-door and 4-door Broncos.
Will there be 0% financing available for the full-size Bronco?
Are wheel/tire combinations and custom gearing an option on all packages?
What is the bolt pattern dimension for the Wheels?
Does the Sasquatch Package have Extended Length Control Arms?
Will the roof racks work on soft top 4-door?
Will the Velocity Blue be available for order with late delivery or a separate ordering scheme?
Is Ford planning to do a nationwide tour of the Bronco line?
Will there be a white grill option?
Can step sides replace rock rails?
Will the H.O.S.S. system with Bilstein® Position Sensitive Dampers be a stand-alone option?
Instrument Cluster type on base model
Will 35” tires fit on non-Sasquatch packages?
Will there be interior material and exterior paint samples at dealers before ordering in December?
Can we option the 4.7 rear without selecting the Sasquatch package?
Does the First Edition include “Roof Rails with Crossbars” standard?
Why no A51 or Cactus Gray on Base? Possible upgraded cost?
Can we please order the Front Lockers without the Sasquatch Package?
Can we please order the HOSS System with Bilstein Position Sensitive Damper without the Sasquatch Package?
Can we please order the Stabilizer Bar Disconnect on models other than the Badlands?
Will the white painted roof be an option for all trims?
Is the roll bar rated for roll overs?
Are ventilated seats an unknown option?
Will customers know which FE number they received?
What is the difference in High Clearance Sasquatch Suspension and the Badlands Suspension?
Do all Sasquatch Broncos come with baja mode or just the Badlands and Wildtrak? And if not, could Baja mode be extended to all Sasquatch Broncos?
Can you please show the Bronco without the fender flares?
Will Saddle Leather become an option?
Can you remove the roof while the roof rack is attached?
Will there be a roof rack/cage that can stay on without the roof?
Will the roof be removable with the cage attached?
Will there be more colors before launch?
Will the 2 door have a smaller version of the 4 door "tray"?
Will the 2-door have a removable rear seat?
How are “add-ons” going to work?
Are there lighter color options for the vinyl? Is the vinyl only available on Black Diamond and Badlands trim?
Will the electronic sway bar disco be offered as a stand alone option?
Do all trims include the same underbody armor pieces (aside from the front bash plate and rock rails)?
What is the actual difference in the "upgraded bash plates"?
Are active grill shutters omitted on Badlands trim? If so, why? For the water depth spec?
What does the high-level instrument panel add over 8" panel in base trim?
Will base model buyers have the option of selecting alternate differential gearing?
Is navy the only First Edition interior option available or will there be more?
Will the LED fog lights and power switch/button remain with the upgraded(steel) bumper on Big Bend and Outerbanks?
What are the dimensions of the cargo area for the 2-door and 4-door?
Please clarity the height specs from non-Sasquatch to Sasquatch package?
Is a 2" lift going to be an option on all trims?
Will there be a 2-door soft top option?
Can buyers opt for the 33” tire and wheel combo on all trims?
Can you confirm expected delivery of Job #1 to be Spring 2021?
How many Broncos are projected to be built per day?
When are you projecting production to commence?
Will Bronco be X-plan eligible in Canada?
Why is the manual transmission not available with the Sasquatch package?
Are the Rock Rails mounted to the body or the frame?
Will the steel rear bumper be available separately?
What is the difference between the bash plates (Base, BB, OB, WT) and upgraded bash plates (BD, BL)?
Will the upgraded bash plates be available separately?
Can the hard top cover driver/passenger without the rear clamshell cap on the vehicle?
Can you please confirm the date when the Bronco configuration tool goes live including option pricing?
Are you going to reallocate First Edition models that were reserved but the orders weren’t followed through?
Can buyers opt into the marine grade vinyl and rubber flooring for any trim package?
Which factory trims/tires will support snow chains?
Are the rear quarter windows removable on all hard tops or only the painted tops?
Is Job #1 mid-March?
White top avail all trims?
Is the 2-door back seat being reworked to be more easily removable?
Will you be adding the manual transmission to the 2.7l engine in the future?
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
“Our roof rack is designed to allow the 2 front row panels to be removed on the 4-door Bronco, and the 2 front row roof panels on the 2-door Bronco to be removed with the roof rack in place.”
BroAD
BroAD
Adam
Illinois
2012 Ford F-150
They are coming in slow so I’ll post here as well unless they pick up the pace:
“Active drain plugs are only available with the rubberized flooring. There are passive drain plugs in all 2- and 4-door Broncos.”
Lilj4425
Jacob
Greenville, SC
Twitter question:
“Hoping these get answered. I have a Black Diamond 2 door on Reserve.
4.Rubber floor,vinal interior,sway bar disco,lockers “al a cart”?”
Ford’s response:
“1. We hear you and are listening
4. Rear lockers are available on most series as a free standing option and front & rear combo lockers are available on all series with Sasquatch.”
Bronco4
Frank
Medford Oregon
2017 F350 CCLB
Love to see carpet delete with First Edition
jaruss01
NJ
Thanks. So sounds like panel above rear seat on 4 dr CANT be removed with the roof rack in place.
guess not that big of a deal since if you need a roof rack and plan on having say a thule, you wouldn’t want to remove the mid panel anyway
BlueBronco
DFW
Considering the whole twitter Q&A is commenting on future products, I find it interesting they pulled out this tired line for this question. Reading between the lines, did they just say yes?
Ford Bronco Ford's Answers to Bronco Questions Submissions (Q&A) 1596225073855
dgorsett
colorado
F250, Mustang, Explorer
Twitter question:
Ford’s response:
4. Most series?? Base?
bladsquatch
Cameron
Crete, Greece
2013 F150
Twitter question:
Ford’s response:
Yessssss. Manual with 2.7!!!
Lilj4425
Jacob
Greenville, SC
Regarding the doors:
“We designed them to be as easy to lift and remove as possible. The heaviest door on the 4-door Bronco will be a little over 50 pounds and can be stored in the cargo space.“
