Ford Bronco Fender Flares in stock at TMB!
Status
Not open for further replies.
ticklemybronco
Josh
Salem Ohio
2022 Bronco 4-door
Bushwacker Fender Flares for 2020-2021 Ford Bronco Sport
Bushwacker Pocket Style® Fender Flares are a Bushwacker original and an off-road icon with their recessed stainless steel bolts and massive presence. These flares are custom designed to complement oversized tires while providing premium tire protection. When you need maximum tire coverage with minimum time and effort, it's in the pocket.
Pocket Style Fender Flares from Bushwacker. Front Flare Height: 4.25 | Front Flare Tire Coverage: 1.50 | Rear Flare Height: 4.75 |
Fitment: 2021-2022 Ford Bronco Sport
Bushwacker 20961-02 Fits 2021-2022 Ford Bronco Black Extend Fender Flares 4pc
You've equipped your vehicle with oversize wheels and tires for serious off-road traction and clearance. Now you need extra tire coverage to protect your rig's body and maybe even comply with local laws.
Bushwacker Extend-A-Fender Flares deliver premium-grade protection and style matched to oversized tires, yet as tough as they are, they go on easily with no drilling required.
You can install them in minutes and enjoy them for years.
Our exclusive Dura-Flex 2000 material is designed for added durability and flexibility with built-in UV protection.
Your Extend-A-Fender Flares resist chalking, cracking, and warping, whether you leave them with their OEM-style matte black finish or paint them for a totally personalized look. Either way, your truck will look factory-equipped for your off-road tires.
Extend-A-Fender Flares go on easy, perform tough, and look great. Extend-A-Fender Flares Black Smooth Finish 4-Piece Set.
Bushwacker 20960-02 Fits 2021-2022 Ford Bronco Black Pocket Style Extended Fender Flares 4pc
With their recessed stainless steel bolts and massive presence, Pocket Style Fender Flares are a Bushwacker original and an off-road icon. They give you the hard-core look of bolt-on flares, with no body-side sheet metal drilling required. Pocket Style Fender Flares are custom-designed for your vehicle to complement oversized tires and high-clearance lift kits.
You can mount them right out of the box with their tough, OEM-style matte black finish they're UV protected so they won't chalk. You can also paint them to match or accent the body color for a factory-custom look. Pocket Style Fender Flares are made from our thick, warp-resistant Dura-Flex 2000 material and tailor-made for added durability and flexibility on the trail.When you need maximum tire coverage with minimum time and effort, it's in the pocket. Pocket Style Fender Flares from Bushwacker. Pocket/Rivet Style Fender Flares Black Textured Finish 4-Piece Set .
Full Selection Here!
Status
