- Josh
- Apr 25, 2022
- 364
- 521
- 175
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
Superlift 9720 | 2" Lift Kit Fits 2021 - Current Ford Bronco
2 inch Lift Kit - 2021-2022 Ford Bronco - 4WD - Non-Sport - without Sasquatch Package - Will not fit
Established in 1975, Superlift remains a pioneer in the industry, and is one of the few suspension companies operated by true truck and off-road enthusiasts.
We are passionate about trucks, wheeling and an outdoor lifestyle that go hand-in-hand. We can talk the talk because we walk the walk.This question.... ''What's best for the customer?''... is always at the top of our list in everything we do, from product planning and design to customer service. This simple guiding principal has served us well for decades, and will continue to guide us into the future.We are proud to provide the truck, Jeep and SUV owner products that perform better than advertised. We understand that most people spend the majority of their windshield time on-road, and our designs reflect this.
You will be 100% satisfied with our products on-road or off - we guarantee it! Determining what product is right for your vehicle and lifestyle can be a complicated task, especially with so many companies and options to choose from. We urge you to carefully research your purchase. Most lift kits represent a considerable investment, and you will literally live with your choice for years. Talk to fellow off-roaders, and your local automotive specialty shop before making a purchase. We love to talk shop, and we encourage you to give our tech staff a call. Bottom line... if you do your homework, you'll discover that we've done ours.
Fabtech 3" Uniball UCA Lift Kit for 2021-2022 Ford Bronco
Fabtech’s high-quality 3" Bronco lift kit offers increased height to run 35" tall tires with additional front suspension strength. This kit helps level the vehicle stance front to rear for a more aggressive appearance.
The factory Bronco upper control arms are replaced with Fabtech’s Uniball Upper Control Arms that provide additional wheel travel with an extra degree of caster compared to stock arms. The increased caster helps to balance steering effort with oversized tires.
The Fabtech upper control arms are constructed of the finest material with .120" wall 1.25" OD 4130 Chromoly steel tubing. High-quality 1" FK Stainless PTFE lined Uniball bearings are utilized in place of the small factory ball joints and allow for increased travel without binding. These super stout Bronco upper control arms are designed for longevity in rugged offroad conditions while providing a more positive on road feel.
The factory front and rear Coilover shocks are retained and receive spacers that provide height while maintaining the comfortable stock highway ride quality.
With the increased ride height, the rear axle becomes offset to the vehicle. Fabtech addresses this with a heavy-duty track bar relocation bracket that re-centers the axle under the vehicle. This provides proper tracking of the axle to the vehicle as Ford intended it.
This Bronco lift kit is an affordable suspension upgrade for enthusiasts that desire to run 35" tall tires with Fabtech quality and strength.
FEATURES
Arms eliminate upper ball joint w/ super strong 1″ ID Stainless American Uniball
Chromoly tubing reduces flex found in stock arms for more positive road feel
17-4 Stainless Steel Heat treated Uniball pin fits into factory ball joint taper without modification to the spindle
Retains stock Coilover shocks for a factory ride
Heavy Duty Track Bar bracket re-centers axle under the vehicle for proper tracking
Great system for the daily driver that requires increased offroad performance
5 Year 60,000 Mile Powertrain Warranty
Rough Country 40100 Fits 2021-2022 Ford Bronco Sport 1.5in Lift Kit
Rough Country's 1.5" lift kit is exactly what your 2021 Ford Bronco Sport needs to achieve the aggressive look it was meant to have. The bolt on spacer kit is easy to install, and offers you an enhanced lifted look without sacrificing ride quality. This 1.5" kit accommodates 245/65 R17 so you can complete the classic off-road styling that Bronco is known for.
FEATURES
Lifts and levels the vehicle.
Allows for larger more aggressive tires.
NOTES - IMPORTANT
Does NOT fit Badlands edition.
Does NOT fit First edition.
FabTech FTS22343 4″ Uniball Uca Lift Kit Front and Rear Shock Spacers Fits 2021 Ford Bronco
Fabtech’s high-quality 4"" Bronco lift kit offers increased height to run 35"" tall tires with additional front suspension strength. This kit helps level the vehicle stance front to rear for a more aggressive appearance.
The Fabtech upper control arms are constructed of the finest material with .120"" wall 1.25"" OD 4130 Chromoly steel tubing. High-quality 1"" FK Stainless PTFE lined Uniball bearings are utilized in place of the small factory ball joints and allow for increased travel without binding. These super stout Bronco upper control arms are designed for longevity in rugged offroad conditions while providing a more positive on road feel.
This Bronco lift kit is an affordable suspension upgrade for enthusiasts that desire to run 35"" tall tires with Fabtech quality and strength.
FEATURES
Arms eliminate upper ball joint w/ super strong 1"" ID Stainless American Uniball
Rough Country 51027 Fits 2021-2022 Ford Bronco 3.5in Leveling Kit
Improved Ground Clearance and Ride Quality. The Ford Bronco is back and better than ever! Rough Country has hit the ground running to give your 2021-up Ford Bronco an improved, aggressive stance with a 3.5-inch lift kit! This suspension kit provides everything needed to lift your vehicle, giving you increased ground clearance to run larger tires while reducing the nose-down factory look for a commanding presence.
Innovative Design and Construction. This suspension kit combines the use of aluminum upper control arms and differential spacers to reduce cv angles and ball joint angles. Featuring a set of upper strut spacers that offer uncompromised strength and rigidity gaining lift height is no issue. Completing the rear of this suspension kit included is a rear track bar and brake line relocation that allows you to retain factory-like geometry. This combined setup provides enough clearance to run 35" tires without additional modifications.
Installation. With minor cutting and strut compressor required to install, an estimated timeframe of 3-5 hours this full kit can be installed at home and can be completed efficiently and quickly!
Lifetime Replacement Warranty. Rough Country's 3.5" Suspension Lift Kit is backed with a lifetime replacement warranty towards manufacturer defects. As such, the product is protected from structural and workmanship damage after the date of purchase. With our industry-leading warranty give yourself peace of mind when using Rough Country's Suspension products!
FEATURES
Levels the front with the rear of the vehicle.
Aluminum control arms.
Greaseable high-angle ball joints.
Easy bolt-on installation.
Maintains factory ride quality.
Increased ground clearance.
Upper control arms improve ball joint angle and correct suspension geometry.
NOTES - IMPORTANT
Does NOT fit Bronco Sport models.
Does NOT fit Badlands, Wildtrack, Raptor or First Edition models.
Does NOT Fit Models equipped with Sasquatch Package.
Check Out Our Full Selection Here!
FEATURES
FEATURES
NOTES - IMPORTANT
FEATURES
FEATURES
NOTES - IMPORTANT
