Ford Electric Brake Controller testing?
sportcoupe
Georgia
2023 Bronco
For those that installed the Ford electric brake controller yourself, can you test it to make sure it's working somewhat without a trailer?
Is there any Forscan programming required?
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
No programming step is required if you already have the trailer tow module (which is included in the tow package or if you installed this kit).
And you can test to see if it is working with a multimeter, some sort of load (like a headlight lightbulb), and a few spare wires.
sportcoupe
sportcoupe
Georgia
2023 Bronco
I do have factory tow so the module should be there.
RagnarKon
Bryan
New England
Yup, you'll have it.
So you just need to put some sort of a load on the trailer brake wire out of the 7-pin (like an auto lightbulb). Connect one lead of the bulb to the Trailer Brake pin, and the other onto the ground. Those two blades should be right next to each other (refer to the diagram).
Higher the trailer brake gain, the brighter the bulb should be when you press the brakes.
Ford Bronco Ford Electric Brake Controller testing? 1698185501574
sportcoupe
sportcoupe
Georgia
2023 Bronco
Very good idea. Thanks. I got a project this weekend, install and test.
