I purchased my Bronco brand new in May of 2023. There was a loud audible squeak from the time we purchased the vehicle. On 6/13/24 we took the vehicle in for an oil change where the service department discovered that the vehicle had an oil leak.
After further investigation, they were able to verify that that several bolts were never installed at the factory between the engine and engine mount. This resulted in the engine shifting down and towards the driver's side of the vehicle. The oil pan was riding on the front differential which eventually led to the oil leak.
Ford approved a "repair of the vehicle" under the warranty. Their solution was to simply lift the engine back up and properly bolt it to the engine mount.
Should I be concerned with any long-term damage to the engine, transmission or drive line as a result of missing bolts and shift of the engine?
Dealing with this process through Ford has been extremely frustrating. They do not seem to be concerned or alarmed with the fact that they forgot to bolt the engine to the vehicle. To say that I am disappointed with Ford and how they have handled this process would be a bit of an understatement.
I hope you guys are having better luck with your broncos,
CB
CB
