Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great!
U725Bronco
NorCal
I haven't seen this exact combo posted so I figured I would share since it's pretty slick. This is a 1up hitch extender mounted in the deeper of the two hole options. The end of the extender doesn't stick out past the 35" tire. I inserted the 1up 2" super duty rack so there are a few mm of clearance from the tire when folded. I marked that point with painters tape to insure adequate insertion. 1up says it must be inserted 2" past the expander ball and this is 2 1/2" of insertion. With the rack in this position I can fit my XXL mountain bike on the inner tray with XTR trail pedals and there is no interference with the tire. To my amazement this set-up also allowed me to open the swing gate on the Bronco with the bike removed and the 1up rack tilted down. There is very little clearance, but it works perfectly. It seems like this set-up would also work with 37" tires, but wouldn't allow the gate to open. I may roll with this set-up for awhile before determining if I also want a Kuat Pivot V2. I like the simplicity of this set-up though. One other thing worth mentioning is that the 1up lock for the hitch extender is tough to get the key in place. It works with a single key on my Ford factory hitch since I don't have the wiring harness in place and I can position my fingers to turn the key. This might not work with the wiring harness. Happy trails!
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! hitchextender
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! insertiondepth
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! depth
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! foldedrack
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! bikesid
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! rackback
Ford Bronco Ford hitch, 1up bike rack, 1up extender, Sasquatch - works great! gateopen2
F OR D
BD Green Machine
awesome, saved me some cash. was going to get the swing arm attachment but this is better. gonna have to get a second lock for the extender though.
quick q, does it make it far enough so you can put a pin in the extender? it's a must for me for security and when hauling 4x bikes.
U725Bronco
U725Bronco
NorCal
I used this hitch extender:
https://www.1up-usa.com/product/hitch-extender-2in/
and it comes with the lock. The pin also threads in to minimize movement. I'll probably throw a cable lock around the bike, through the rack and to the Ford hitch when in transit.
F OR D
BD Green Machine
U725Bronco
U725Bronco
NorCal
I just reread your question and realize you were asking about a pin in the extender....yes, it fits with this 1up rack. I was just too lazy to install it for the photo.
U725Bronco
U725Bronco
NorCal
nice, can you fit a pin through the extender hole and the hitch?
Yes, with the newer 1up racks. The older 1up racks didn't have the slot for the pin, but the new ones do.
Mustang_75_99
Northern Illinois
2014 Ford F150, 2005 Mustang GT
Do you think this extender would be sturdy enough to support a 4 tray bike rack?
U725Bronco
U725Bronco
NorCal
I think so. This is a very beefy extender. The limiting factor is probably the weight limit on your 4 bike tray.
Mustang_75_99
Northern Illinois
Thanks for the feedback.
At this point I only have a dual tray for mine and my wives bike. However, my kids are now on bikes that would necessitate moving to a 4 place tray. Just getting into the market for one, but need to do some research whether it would be worth it for the Bronco.
U725Bronco
U725Bronco
NorCal
It's definitely not the cheapest way to do it, but you could get the exact same set-up I listed here, then add a couple single tray add ons from 1up. You could then decide if you mount 2, 3 or 4 trays depending on how many people are biking.
Chelada
Bulverde, TX
2022 Bronco
Does your camera get blocked with the rack folded up? If it does I'm considering getting the Kuat Hi Lo extender. The 1Up extender would be nice since they can key both locks the same.
F OR D
BD Green Machine
yes, usable but about 30% blocked on the bottom. actually thinking about a rc or 4wp tire relocation kit. moves it up about 2.5", may help view and if/when i get some bigger tires.
BroncoDEPR
Jorge
Lexus GX470
Im running the same set up with 3 full suspension bikes on a Badlands On 35’s currently with no issues. 4 bikes shouldnt be a problem. .
