- First Name
- Lara
- Joined
- Jan 8, 2022
- Threads
- 0
- Messages
- 14
- Reaction score
- 11
- Location
- San Jose, CA
- Vehicle(s)
- 21 Bronco Big Bend
- Your Bronco Model
- Big Bend
I haven't seen this exact combo posted so I figured I would share since it's pretty slick. This is a 1up hitch extender mounted in the deeper of the two hole options. The end of the extender doesn't stick out past the 35" tire. I inserted the 1up 2" super duty rack so there are a few mm of clearance from the tire when folded. I marked that point with painters tape to insure adequate insertion. 1up says it must be inserted 2" past the expander ball and this is 2 1/2" of insertion. With the rack in this position I can fit my XXL mountain bike on the inner tray with XTR trail pedals and there is no interference with the tire. To my amazement this set-up also allowed me to open the swing gate on the Bronco with the bike removed and the 1up rack tilted down. There is very little clearance, but it works perfectly. It seems like this set-up would also work with 37" tires, but wouldn't allow the gate to open. I may roll with this set-up for awhile before determining if I also want a Kuat Pivot V2. I like the simplicity of this set-up though. One other thing worth mentioning is that the 1up lock for the hitch extender is tough to get the key in place. It works with a single key on my Ford factory hitch since I don't have the wiring harness in place and I can position my fingers to turn the key. This might not work with the wiring harness. Happy trails!
